Example: Direction of the VRaySun Light
Note: All the images below are rendered with Color mapping: HSV exponential, Dark multiplier: 1.0, Bright multiplier: 1.0 unless otherwise noted.
This example demonstrates the effect of the sun direction. The Sun is positioned at certain degrees against the ground. Note how in addition to the scene brightness, the sun position also changes the appearance of the sky and the sun light color. Enabled: on, Turbidity: 3.0, Shadow subdivision: 8, Intensity multiplier: 0.01, Size multiplier: 1.0.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
