||mat Network|| > V-Ray > Material > V-Ray Proxy Material
width
33%
||out Network|| > V-Ray Render Elements node > V-Ray > Material > V-Ray Proxy Material
width
33%
Node
width
50%
The V-Ray V-Ray MtlVRayMesh node provides inputs for connecting shaders to a V-Ray Proxy.
width
5%
width
45%
Image Modified
width
50%
VRayProxy
SOP – Use this parameter to point to the V-Ray Proxy in the scene. Once it is selected, the V-Ray MtlVRayMesh node creates inputs for every shape or object in the proxy. Shaders can then be connected to them.
