Section | |||||||||||||||
Anchor layers.maya layers.maya
UI Text Box | ||
When adding a new layer, it is placed on top of the stack and it is considered the foreground (FG). The result of all layers below it is considered the background (BG). Layers are applied from the bottom to the top. Where darker and lighter pixels are mentioned below, it is in relation to mid-grey. |
Anchor | ||||
Display Correction
UI Text Box | ||
Normally you would specify the ICC file for your calibrated monitor here. Programs like PhotoShop display images using your (primary) monitor's ICC profile automatically. However (at least for the moment), Maya is not a color-managed application and you must manually load the monitor ICC profile into the V-Ray frame buffer in order to match the appearance of your images in PhotoShop. |
ICC
LightMix Mode
Lens Effects
Background
Constant
Section | |||||||||||||||||||||||||
Constant
Hue/Saturation
Exposure
White Balance
Hue/Saturation
Color Balance
Curves
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
UI Text Box | ||
When working with .acv files, some approximations are performed because the curves in the .acv files are described by a different mathematical formulas. |
Filmic Tonemap
Example: Filmic Tonemap Layer
For the second image in the example below default values of the Filmic Tonemap layer are used. The type is the default Hable.
Example: Filmic Tonemap Types
ICC Profile
Sharpen/Blur
Denoiser
