The Back To Beauty render element is a single Render Element that expands as all beauty elements for the actual rendering. When used with with V-Ray Frame Buffer (VFB), this render element creates a folder in Composite named BackToBeauty containing containing all elements with the appropriate blend modes.When used with V-Ray Frame Buffer (VFB), it only generates the layers without compositing them.
When VRayCaustics is used with VRayBackToBeauty and the render engine is set to V-Ray GPU, VRayCaustics is not added to the render.
VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mappingrollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
