The Unclamped Color Render Element is a color image that shows the original colors that were clamped. This render element is useful in the compositing process for enhancing extreme colors (very bright or very dark) or for shading the final image with the unclamped colors.
width
5%
width
45%
Image Removed
UI Expand
title
UI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||> Render Elements tab > Addbutton > VRayUnclampedColor
Image Added
width
20%
5%
width
60%
45%
Image Modified
width
20%
width
60%
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Add background – When enabled, adds the background to the render element.
