You can also use Chaos Player to view the different channels of EXR and VRIMG files. This way of handling information allows for multiple layers to be played simultaneously while applying changes in real time. You can fully control the way layers are composed together and how they are set in the timeline. You can also scale each layer independently and change the aspect ratio independently or globally for all layers. Chaos Player allows you to move layers in an infinite workspace.
Anchor | ||||
Speed and Smart Caching
Chaos Player is designed for fast playback of multiple image sequences simultaneously. Each sequence is cached independently, which allows further adjustments like color corrections or position transformations to be done in real time and even while playback is running.
You can also export your project to a Chaos Player .chpcmd Command File that can be used for automation later on.
Layering
Chaos Player is built to handle playback of multiple sequence inputs layered together. Layering can be used in a number of ways: compositing, editing and cutting, a/b wipe compare tech-checks and more.
Anchor | ||||
Compositing
Chaos Player is capable of doing basic compositing. Simple additive Back to Beauty composites from multi-channel OpenEXR files can be with a couple of clicks, but additional blending modes are also available.
