Anchor
6.20.
6.20. |
06 6.
06 | |
6. |
20.
20. |
06
Build 6.
06 |
20.
06
Official release, Update 2.1
Date – December 20April 02, 2023
UI Button color blue newWindow true icon download title Download V-Ray 6 for 3ds Max url https://download.chaos.com/?platform=49&product=47
color | blue |
newWindow | true |
icon | download |
title | Download V-Ray 6 for 3ds Max |
url | https://download.chaos.com/?platform=49&product=47 |
New Features
V-Ray
- Support for 3ds Max 2025
- USD support in Chaos Cloud
- USD - support for MaxUSD 0.7.0
V-Ray GPU
- Use System Memory mode for texture loading
Modified Features
V-Ray, VFB
- Add ability to save Cryptomatte channels separately from the raw image file
V-Ray
- V-Ray toolbar's create mesh light button should be disabled for incompatible selections
- Support for texture filtering for MaterialX files which use UVWGenExplicit
- Improve deletion of selected objects in VRayLister
- Add Directional strength for V-Ray Lights in V-Ray Lister
Bug Fixes
V-Ray
- Specific frames rendering black in V-Ray Standalone
- 3ds Max 2025 crashes with Active shade enabled
- Crash with Convert bitmap to tiled exr/tx and specific file
- Wrong result with VRayTriplanarTex rendering in Standalone
- Rendering discrepancy between 3ds Max and V-Ray Standalone with very distant and small disc lights
- IPR crash when moving lights in scenes with PhysicalMaterial and emission texture
- Failing redirection of missing Cosmos assets for very old scenes
- Rename the "Autoswitch to effectsResult" label to "Auto-show post effects"
- Crash when linking or unlinking VRayTriplanarTex to VRayBitmap used in ForestPro Material tint while V-Ray IPR is running
- Crash on scene reset, when there are 2 or more lights or cameras with an open V-Ray Lister
- 3ds Max crashes on opening ME if we have Phoenix installed on top of V-Ray
- Multiple "V-Ray viewport IPR" items occur in the quad menu
- Standalone renders consistent lighting elements incorrectly when having matte object in the scene
- RawBitmapBuffer containing .hdr pixels data is not extracted to .tx on Enscape .vrscene import
- Slow import of specific Enscape vrscene with more than 240000 nodes
- Crash with V-Ray CPU IPR when going from Perspective to a VRayPhysicalCamera with Motion blur enabled and a VRayDenoiser Render Element
- Animated V-Ray IES light settings are not exported and rendered with V-Ray Standalone
- Warnings for invalid material evaluation with specific scene
- Incorrect shading of backfacing geometry when there is Phoenix Simulator, V-Ray Volume Grid or Environment Fog in the scene
V-Ray Bitmap to VRayBitmap converter
- VRay Bitmap to V-Ray Bitmap converter do not always replace Bitmaps (UI)
VFB
- V-Ray Standalone Qt6 with autoClose=1 never closes
VRayIES
- VRayLighting and VRayRawLighting are not always rendered when using VRayIES lights
VRayInstancer
- Crash in 3ds Max when rendering Scatter with a hierarchical model which has dummy object in the hierarchy
VRayMtl
- VRayMtl's Fog depth parameter stays greyed out when Thin-Walled is active and we switch from SSS to None
VRayPhysicalCamera
- VRayLister: White balance gets unexpectedly switched when changing Temperature value for several selected VRayCameras
VRayVolumeGrid
- Out of memory Error during building mesh with Phoenix liquid when rendering a scene with V-Ray Standalone on Linux
Build 6.20.02
Anchor | ||||
Date – December 20, 2023
Modified Features
V-Ray
- Register V-Ray Lister in the V-Ray application menu
- Add MaxScript function to show the V-Ray Lister (vrayShowLister())
Date – November 29, 2023
New Features
V-Ray
- Enscape .vrscene importer (Beta)
- One-click submit to Chaos Cloud
- Integrate Chaos Scatter 4 in the V-Ray installer
- Render to texture support for denoising
- USD - Support for latest MaxUSD
- USD - Implement a workflow for material override
- Implement Shadow Select Render Elements
- Import IES-type lights from Cosmos
- Introduce adaptivity clamp in order to avoid high sampling in overexposed regions of the image
- Add the upscale option to the standalone denoiser tool
Modified Features
V-Ray
- Improve ForestPack export for a lot of instances
- Optimize ForestPack edge trimming export
- Improve .vrscene export of hidden geometry
- Improve geometry compiling for subdivision surface objects on high core count machines
- Download the missing asset revision used in the project (Cosmos)
- USD - 3ds Max should export assets paths with a forward slash
- Rendering deep images in progressive mode should save a non-deep image regardless
- Improvements for the V-Ray menu Set default MAX V-Ray UI setting
- Change the Render Setup's UI modes labels from "Default" to "Basic"
- Reveal all the options for the camera types in the Camera rollout
- Move VRayProxy's Object hierarchy to a separate dialog
- Add a label when there are no cameras in the scene and using the flyout render button in the VFB
- Scripting access to Override Material Settings
- V-Ray for 3ds Max Japanese localization
- New icons for the tools shipped with V-Ray
Bug Fixes
V-Ray
- Exception in V-Ray GPU when rendering VRayLight with texture and Spot Light with Projector map
- IPR crashes with standard material nested in override material for USDStage
- Wrong VRayLight intensity when exported to USD and then rendered
- xRef with VRayProxy viewport preview does not load correctly when switching xRef files in stable and nightly builds
- Wrong export of transform list params in plain text
- USD - Crash when rendering USD file containing VRayLight when imported in a scene with a matte object
- Animated mesh normals are not used and instead computed and rendered as smooth normals
- Converting .vrimgs to multipart .exrs via the vrimg2exr tool makes some denoiser elements unrecognizable by vdenoiser.exe
- A scene with VRayDecal, Switch material and user-defined properties takes too much time to unload after a render is stopped
- USD Material Interface handling in V-Ray for 3ds Max
- Slowdown when rendering VRayHairNextMtl with opacity in comparison to V-Ray 5.1
- USD - Changes in UsdStage session layer are not rendered
- Incorrect minimum value for geometry samples in QT UI Render setup Camera rollup
- Some LPE presets for render elements are incomplete
- Add support for animated crop parameters of Bitmap/VRayBitmap when exporting to a vrscene file
- Incorrect rendered output of RE due to conflict between NVIDIA AI Denoiser with enabled Upscale and change in resolution during submission to the cloud
- V-Ray / V-Ray GPU result discrepancies when exporting animated objects and motion blur enabled
- Assets of type "material" import with multiple VRayUVWRandomizer nodes
- VRayNormal nodes are always imported with "Flip green" turned on
- Crash when editing VRayBitmap filename with frameNum tag
- V-Ray GPU crashes with Render Mask with empty Include list
- Black viewport display of large textures with VRayBitmap
- 3ds Max crash with X-ref scene and LiveLink
- Crash in V-Ray Standalone when rendering Forest Color using empty VRayBitmap as default map
- Motion blur geometry samples override per object is not exported when the animated mesh remains on the same position
- VFB Real Zoom doesn't update correctly in GPU IPR with V-Ray Cameras with enabled Resolution override
- Crash when rendering TyCache (TyFlow) with Edit mesh modifier only in animation
- Mis-loading of frame-numbered ABC sequences
- 3ds Max crashes with imported USD file and running IPR
Overrides are not working when enabling Use alembic offset in VRayProxy with Include visibility lists
Visibility override is not working for VRayProxy with visibility lists after making it unique
Chaos Scatter's Edge trimming does not render correctly in V-Ray GPU when we have multiple Multi/Sub-Object materials applied to the instanced objects
Chaos Scatter's Edge trimming renders incorrectly in V-Ray GPU on instanced objects with Multi/Sub-Object when Override mtl is used
The top level materials imported along with geometry assets get non-unique names
Scatter-instanced models' materials might get exported incorrectly on duplicated names
Discrepancies with Standalone when using a material with VRayBitmap with no tiling, Alpha source set to None and a custom UVW map
Error with the V-Ray Proxy exporter when object name contains slash symbol
Inconsistent rendering of Scatter during GPU IPR session with delete/undo
Rare crash while obtaining a license
Wrong symbols in VFB compare settings when Chinese UI is used
Viewport GPU IPR renders black when started from a camera viewport with enabled Resolution Override
Typo in Submit to Chaos Cloud rendering window UI
Crash when switching between VRayPointCloudColor maps in Compact ME
Huge slowdown with alembic with complex hierarchy loaded in VRayProxy
Override mtl include option is not transferred when switching between V-Ray/V-Ray GPU
Deep output: certain channels should be always 32-bit
Some of the settings in Translucency are not grayed out when Volumetric is used in combination with Thin-walled in VRayMtl
Cloud Preview resolution is not respected when VRayPhysicalCamera's Resolution override is used
USD - Crash when exporting to USD as animation range VRayProxy with nondefault Scale value
Explicit normals are changed to Unspecified for modified Proxy nodes
Motion Blur does not affect VRayTriplanarTex when applied to VRayProxy
Camera creation for ortho views needs a default target distance value
Command panel gets resized when VRayProxy object is selected
V-Ray GPU crash when rendering TyFlow cache with motion blur with a specific scene
Endless compiling geometry step to displaced alembic in V-Ray Standalone
Vraylog overwhelmed with: Object () may require 2-sided lighting: material () is potentially translucent
Wrong mapping at UV seam with Normal maps in 3ds Max
Animated rotation of HDRI rendered with Backburner/Deadline and V-Ray GPU differs on each machine
VRayUVWRandomizer's Coordinates Rollout UI not responding to animated parameters
Isolate Locked Selected does not lock onto nodes in the Material Editor
V-Ray Ambient light is not illuminating when exported
Material color swatch is not rendered outside of VRayHDRI placement when the map Opacity is set to None
No extension on vrmesh files if deleted when choosing a file name
Slow progress printing due to unconditional console code page changes
BitmapBuffer reported black as an invalid color
Saving a TIFF file with the SaveTIFFile() function in pimglib swaps the red and blue components
Slowdowns in Embree when multiple dynamic objects are expanded at the same time
LPE light tags support
VRayProxy with assigned Multi/Sub-Object material in V-Ray GPU has incorrect shading with material override
Access violation during closure code generation with LLVM 12
LC samples should not be increased when rendering minuscule regions
Changing any settings or changing the timeline frame of Simulators or Particle Shaders in Volumetric Mode does not update in V-Ray CPU IPR in Maya
Official release, Update 1.2
Date – May 3, 2023
New Features
V-Ray, V-Ray GPU
- Add initial support for RAW render elements in V-Ray GPU
Modified Features
V-Ray
- Optimize vrscene export for ForestPack and motion blurred Anima assets
Bug Fixes
V-Ray
Cosmos auto-downloader should not modify or consider proxy/bitmaps pointing existing files
VRayBitmap preview in Max 2024 Viewport is wrong when using Max Color Management
V-Ray properties' values cannot be bulk-changed
Render crash with hidden grouped objects added to the light exclude list
EULA does not get accepted when a 2-byte character is used in the username
Progressive resumable rendering could leave corrupted files in case of a system crash during saving
Official release, Update 1.1
Date - April 11, 2023
New Features
V-Ray
- Support for 3ds Max 2024;
- Support for Material Switcher material in 3ds Max 2024;
- Support for material compounds in 3ds Max 2024;
- Chinese translation is implemented.
Modified Features
V-Ray, VRayDecal
- Add "Render when hidden" option to VRayDecal;
- Implement Qt UI of Max Physical Camera V-Ray attributes;
- Implement Qt UI of VRayVRmatMtl;
- Implement Qt UI of VRayShadows RE;
- Implement Qt UI of VRayStereoscopic;
- Implement Qt UI of VRayBitmap;
- Implement Qt UI of VRayDomeCamera;
- Implement Qt UI of VRayExposureControl;
- Implement QT UI of Caustics rollup;
- Implement Qt UI of VRayLightMix and VRayLightSelect RE;
- Implement Qt UI of VRayPtex;
- Implement Qt UI of VRayICC;
- Implement Qt UI of VRayLut;
- Implement Qt UI of VRayLightMeter;
- Implement Qt UI of VRayMDLMtl;
- Implement Qt UI of VRayOCIO;
- Implement Qt UI of VRayOSLOutputSelector;
- Implement Qt UI of VRayOptionRE;
- Implement Qt UI of VRayPhysicalCamera;
- Implement Qt UI of VRaySphere;
Bug Fixes
V-Ray
- IPR crashes with IPR Debug Shading toggled;
- Incorrect render for multiple copies of same proxy with different mesh sets reorder/remapping;
- Black Viewport IPR rendering with NVIDIA AI upscale VRayDenoiser;
- VRayBitmap mixup in GPU IPR when Anima 4D characters are added via the anima Drop option directly in 3ds Max;
- V-Ray GPU with NVIDIA AI upscale denoiser produces an output of 1/4 of the desired resolution when the image is saved from the Common tab Render Output;
- Cosmos assets auto-download on scene open crashes if there are currently ongoing Cosmos downloads;
- Crash with Forest Pro if 3ds Max Photometric (IES) lights are used in scene;
- VRayExtraTex render element typo "lossess compression";
- LPEs don't consider 3ds Max native Lights;
- Displace is not greyed out when Direct illumination is checked in VRayLightMtl;
- Crash when turning Enable GI on/off in scenes where the legacy Expert mode of the rollout is set;
- Turn off Temporal mode in VRayDenoiser when NVIDIA AI upscale is on;
- Keyed frames VRayLight Directional parameter doesn't export correctly;
- After importing specific Cosmos assets the translation of objects does not behave properly and undo stops working;
- PointCloud does not work with VRayLightMix;
- VRayUVWRandomizer in VRayBitmap Mapping source bug;
- Show render log' button in V-Ray GPU Render Setup does not work;
- VRayLight caustics multiplier is not exported to vrscene;
- Export render region from the context menu scene exporter;
- VRayLight properties are not exported;
- Override Material Include and Exclude list does not work in V-Ray GPU;
- Hidden Particle Shader is still rendered visible in V-Ray Standalone (.vrscene export) when it is part of the Multimatte include list;
Official release, Update 1 Bugfix
Date - March 16, 2023
Modified Features
V-Ray
- Make the error 'Ignoring material LPE label "base"' a warning;
Bug Fixes
V-Ray
- Various fixes for Deferred loading of the VRayBitmap viewport previews;
- Fix issues with the "manual" mode of the LightMix render element;
- V-Ray GPU with upscale denoiser produces an output of 1/4 of the desired resolution when the image is saved from the Common tab Render Output;
- Global Switches' Override spinner arrows not responsive with values between 1 to 10;
- GI settings panel views don't switch in 3ds Max 2018;
- Error for auto-backup when the Material override is enabled without material;
- Specific VRayMultiSubTex configuration render very slowly with motion blur;
- Exporting .vrmeshes to separate files does not work when the folder has multibyte characters;
Date - Feb 21, 2023
New Features
VFB
Add masking support for Lens Effects and Denoiser layers in the VFB;
Support for comparing VFB History images with their own Layer Stacks;
Add custom color space options for the VFB Background layer;
Add Light Mix Render Element from the VFB directly;
- Add an "invert" option to the VRaySphereFade atmospheric, similar to the one in Maya;
Modified Features
V-Ray
- Make the VRayDecal mask blend for displacement;
- Instancing 3ds Max .vrscene export support for VolumeGrid;
- Export of animated film gate of VRayPhysicalCamera;
- Warning in the Scene Analyzer for scenes with Irradiance map;
- Silent installation changes the .xml file values;
- Ability to specify channel numbers for UVs and other alembic arbGeomParam data;
- Improve context menus of material and map buttons;
- Improve VRayLightMix's right-click menu;
- Expose the DeleteResumableFileOnSuccess option in the V-Ray for 3ds Max interface;
- Progressive caustics performance improvements
- Optimize OSL headers loading;
- Improve the machine info printed in the log in V-Ray Standalone or by the -version flag;
- Support for long error messages;
- CPU IPR should read the mtl_maxdepth settings;
Remove 'maxver' global from vrayutils.ms to avoid clashes;
Shadow opacity optimizations;
Detect missing Cosmos assets and auto-download them on user choice;
Embed standard OSL header files into the OSL library;
Add frame index as OSL shader attribute;
Expose access to shutter time in camera shaders;
Expose time global variable in camera shaders for GPU;
Changing the name of the VRayNoiseTex when copying it;
- Add an Affect Alpha option in the VRayEnvironmentFog and VRayAerialPerspective;
Replace VRaySun's .enabled parameter with .on (maxscript);
- VRaySwitchMtl's nodes and properties Materials to be with the same numerations;
Show the VRaySwitchMtl sub-material in the viewport in respect to the current switch value;
- Implement Qt UI of VRayMetaball;
- Implement Qt UI of VRayDecal;
- Implement Qt UI of VRayRenderId RE;
- Implement Qt UI of VRayZDepth RE;
- Implement Qt UI of VRayWireColor RE;
- Implement Qt UI of VRayVelocity RE;
- Implement Qt UI of VRayUnclampedColor RE;
- Implement Qt UI of VRayVectorDisplBake;
- Implement Qt UI of VRayToon RE;
- Implement Qt UI of VRayMtlSelect RE;
- Implement Qt UI of VRayRaw/Refraction/Reflection/Filter RE;
- Implement Qt UI of VRayObjectID RE;
- Implement Qt UI of VRayMtlID RE;
- Implement Qt UI of VRayLightingAnalysis RE;
- Implement Qt UI of VRayExtraTex RE;
- Implement Qt UI of VRayDRBucket RE;
- Implement Qt UI of VRayCryptomatte RE;
- Implement Qt UI of VRayAO RE;
- Implement Qt UI of V-Ray Object properties;
- Implement Qt UI of VRayDisplacementMod;
- Implement Qt UI of VRayDenoiser RE;
- Implement Qt UI of VRayInstancer;
- Implement Qt UI of VRayHairFarmMod and VRayOrnatrixMod;
- Implement Qt UI of VRaySamplerInfo RE;
- Implement QT UI of System rollup;
- Implement QT UI of GI rollup;
- Implement QT UI of Color mapping rollup;
- Implement QT UI of Tiled texture options and Proxy preview cache rollups;
- Implement QT UI of Light Cache rollup;
- Implement QT UI of Camera rollup;
- Implement QT UI of Image Sampler and Image filter rollups;
- Implement Qt UI of VRayAtmosphere RE;
- Implement Qt UI of vrscene export and cloud submit dialogs;
- Implement Qt UI of VRayDirt;
- Implement Qt UI of VRayEnvironmentFog;
- Implement Qt UI of VRaySSS2 RE;
- Implement Qt UI of VRScansZone and VRScansPMaskElement REs;
- Implement Qt UI of VRayFur;
- Implement Qt UI of VRayGLSLTex;
- Implement Qt UI of VRayGLSLMtl;
- Implement Qt UI of VRayOSLTex;
- Implement Qt UI of VRayOSLMtl;
- Implement Qt UI of VRayIES;
- Expose tooltips for Qt UI of VRay Materials/Maps and Render Setup in 3ds max versions 2020-2019;
- Implement Qt UI of VRayObjectSelect and MultiMatte REs;
- Implement Qt UI of VRaySun;
- Implement Qt UI of VRayAmbientLight;
- Implement Qt UI of VRayLight;
- Implement Qt UI of VRayPlane;
- Implement Qt UI of VRayScene;
- Implement Qt UI of VRaySphereFade;
- Implement Qt UI of VRayAerialPerspective;
Implement Qt UI of VRayToon;
Bug Fixes
- Camera Motion Blur doesn't work in IPR;
- Incorrect IPR results when excluding an object from the Source Light instanced by VRayInstancer;
- Incorrect values when using only one of the input color components on GPU/Standalone;
- After importing specific Cosmos assets, the translation of objects becomes abnormal and Undo stops working;
- VRayCompleteMap baking element disappears from the V-Ray GPU rollout;
- 3ds Max crashes when a USD file, created by the Omniverse exporter, is rendered in V-Ray;
- Random crash when starting IPR from VFB with specific scene;
- The translucency of the VRayMtl is not written to the albedo render element;
- Render mask on Layer mode does not respect Layer hierarchies;
- Bucket size is transferred to V-Ray GPU, when set in V-Ray CPU;
- VRayMtl Environment Map field missing from UI in 3ds Max 2018;
- Region rendering disabled in IPR when "Built-in Buffer" is disabled;
- Cosmos lighting assets import with the wrong mode;
- VRaySheenReflection render element causes difference in VRayTotalLighting element in specific scene;
- Crash on .vrscene export with Separate files option=on and any of the sub options disabled;
- Incorrect IPR results when excluding an object from cloned (instanced) VRayLight's exclude list;
- Incorrect export of VRayLight' s animated parameters to USD;
- If a viewport is maximized all 4 viewports show their borders when dropping a Cosmos 3D asset;
- Occasional crash on downloading missing assets from Cosmos;
- Use world units spinners for the VRayMtl's "Dim distance" and translucency "Thickness";
- Cosmos materials with fog are imported incorrectly;
- V-Ray installation overrides newer Cosmos installations with an older one;
- Animated Alembic meshes produce incorrect velocities when modifiers are applied;
- Empty rollouts when opening scene with obsolete Expert UI mode setting;
- Crash while downloading multiple misallocated Cosmos assets to use with current scene;
- VRayDistanceTex not properly updating upon object movement in V-Ray GPU;
- 3ds Max 2018 crashes when a VRayMtl is created or copied in the Material Editor while the IPR is running;
- Random crash when rendering a sequence, using Live Link with Vantage;
- Wrong render of the ZDepth render element with Catmull-Rom Image Filter;
- Difference in export with VRayNormalMap when a map is used in the bump map slot;
- Crash with an empty VRayEnmesh reference objects list in V-Ray Standalone;
- Changes to a material in the CME do not show in the viewport in real time;
- Diffuse color changes from Compact material editor are not updated in the viewport;
- Anima characters not following walkway path on scene export;
- Discrepancy in Standalone with visible Dome lights and VRayZDepth;
- Anima 4D characters rendering distorted in Standalone animation;
- UV Space Map channel for VRayNormalMap is not exported;
- Crashes with NormalBump on instance delete and undo or creation;
- Including/Excluding a light through the trace sets in the V-Ray Properties of an object does not work correctly;
- VRayInstancer does not render properly VRayLightMtl in VRender and Standalone GPU/CPU, when Direct Illumination is On;
- Export render region from the context menu Scene Exporter;
- Various Atmospheric gizmos used with VRayEnvironmentFog are rendered with uniform shape when exported;
- Forest Color map produces color tint artifacts/variations in Element mode in GPU IPR;
- Main channel selection in the Standalone Denoiser not working;
- LPE light tags support;
- Longer render and load time with Alembic compared to VRmesh;
- Compile geometry is slow when there are 735 proxy files referencing the same .vrmesh file;
- Specific Tiled EXR file returns black color when applied as texture, due to only channel present in file being rgb.R;
.vrscene file path is reduced to 256 characters;
- The Loop Time Bend mode treated as Direct Index mode when exporting from 3ds Max to vrscenes, rendering with V-Ray GPU or on the Chaos Cloud;
- V-Ray Distance texture used as a Fire opacity mask doesn't update properly during sequence render with V-Ray GPU;
Can't animate the 'Fire Multiplier', 'Physically Based', 'Fire Opacity Mode' and the Smoke Color 'Based On' parameters when exporting to V-Ray Scene;
The Mesh of the VolumeGrid has Vertical Fade level erroneously applied to it and it can't be turned off;
Crash when rendering with Scanline after the scene has been rendered with V-Ray;
The Render Elements might render black with freshly started 3ds Max and Volume Light Cache enabled;
Smoke opacity modulated by V-Ray Distance texture doesn't show the correct result in the viewport GPU Preivew;
Voxel Velocity and Streamline Velocity previews show much less data than they should with Auto Range and a moving VolumeGrid;
The Streamline Velocity preview does not exclude the inertial velocity of a moving container like the old Velocity preview does;
3ds Max crashes when rendering in Isosurface Render Mode and a Gradient Ramp texture, set to Lighting Gradient Type, is used as a V-Ray Environment texture map;
Saved images from the GPU preview with frames outside the timeline have cache indexes clamped to the nearest timeline frame;
VRayPluginNodeTex map in the Bump map slot renders with different strength after export;
- Displacement applied on a Decal does not render correctly on the opposite side of the camera;
VRayDecal mask is not clamped;
- Mismatch in Diffuse shading and displacement using the same Triplanar texture;
- Cryptomatte masks for lights are not working in V-Ray GPU;
- CUDA error 700 appears when toggle off/on the Volumetric Environment set to Fog during Interactive render with GPU;
- 555f00prism.vrscan causes Maya to crash when GPU render is started;
- Crash with NVlink and artifacts with V-Ray light positioned exactly at 90 degrees and matte surface, using V-Ray GPU;
- VRayMultiSubTex in Random By Element mode with dynamic geometry produces incorrect results;
- Crash when using Refraction+Alpha on specific object;
- VRayDecal with disabled 'Use decal user properties' renders differently in V-Ray GPU;
- Wrong clipped VRayLights objects with OOC when VRayClipper is set with Use Object Material;
- GPU Light cache freezes when scrubbing the timeline during IPR with specific scenes;
- Reflect/Refract Affect All Channels doesn't work with VRayBackground RE;
- Crash in V-Ray GPU IPR with BF+BF and refractive glossy VRayMtl when changing translucency modes;
- Difference between CPU and GPU with VRayMultiSubTex Random By Element and non-default motion blur geometry samples;
- Textures on objects are not rendered correctly with motion blur and viewport subdivision;
Dynamic geometry doesn't update in Interactive when deformed;
Override Material's Preserve Original Opacity does not work with VRayFastSSS2 and VRayALSurfaceMtl;
VRayScatter does not work with VRayCryptomatte;
V-Ray, VRayInstancer, VRayMultiSubTex, V-Ray GPU, VRayTriplanarTex
Wrong motion blur with Chaos Scatter and inconsistent ID assignments;
- VRmat exporter with all scene materials causes MAXScript exception when exporting background color textures;
V-Ray Scene Converter does not propagate Strength Mult. parameter from CoronaNormal to VRayNormal;
- Crash when resetting CC Layers stack while Curves are being recalculated;
- Saving an image from the VFB with the Background layer set to "As Foreground" produces black overlay;
- Missing color corrections when uploading an image from VFB History to Chaos Collaboration;
Remove MaxScript commands for the old VFB from the vfbControl list;
- VRayDecal's helper with an assigned material does not update properly its viewport preview when changing its dimensions;
VRayDecal to work with VRayUserScalar/VRayUserColor;
- VRayEnmeshMod does not work with Opacity;
- VRayEnmeshMod's Crop box position is misallocated in 3ds max 2023;
- Enmesh does not properly work with masked decals;
Incorrect results with masked VRayDecal projected on VRayEnmesh;
Artifacts with 5 or more VRayEnvironmentFog gizmos;
VRayGLSL
Crash when deleting the light while rendering a scene with VRayGLSLTex in V-Ray IPR;
- VRayGLSLMtl does not generate render channels in V-Ray for 3ds Max;
Crash with generator_outline.frag;
VRayGLSL, VRayOSL, VRayMDL, VRayPluginNode
Texture used with VRayOSLMtl doesn't show with production rendering;
Thinking Particles object renders despite primary visibility being OFF;
- VRayBitmap's QT Map button in Dome Light doesn't load textures accurately;
- Modifying the settings of existing VRayLight in a previously saved scene transfers them to every other consecutively created light;
Adaptive dome light artifacts when Caustics are enabled;
VRayMDL, VRayGLSL, VRayOSL
- Crash with ill-formed parameter lists in OSL;
Crash after deleting `[[string widget="null"]]` metadata;
- Wrong results when projecting opacity-mapped VRayDecal onto VRayMtl with Refraction or Translucency mode;
- Dragging an HDRI from Cosmos to VRayBitmap input field is not working;
XRef material is populated with the whole material tree in SME on render;
- Incorrect handling of empty camera shader nodes when targeting the GPU;
- OSL preprocessor warnings are treated as errors;
Access violation with camera shaders which make use of `transform()`;
Tiling of input textures not taken into account in V-Ray GPU;
DOF has to be applied when "Bitmap aperture" is active but the bitmap itself is not loaded in VRayCam settings;
VRaySun, VRaySky, VRayAerialPerspective
VRaySky realistic viewport pixels are clamped to 1.0;
- Wrong viewport shading of objects with VRayMtl when assigned from V-Ray Toolbar;
