You can select which GPU device(s) to be used by the NVIDIA AI denoiser via the Select rendering devices for V-Ray GPU for 3ds Max #### tool. with the following environment variable - VRAY_OPTIX_DENOISER_PLATFORMS. For more information, see the Environment Variables page.
UI Text Box | ||
In earlier versions of V-Ray 6 for 3ds Max, Beta, the environment variable , you can select which GPU device(s) to be used by the NVIDIA AI denoiser with the following environment variable - VRAY_OPTIX_DENOISER_PLATFORMS is deprecated. Instead, use the redesigned Select rendering devices for V-Ray GPU for 3ds Max #### to set GPU devices for denoising. |
. In V-Ray 6, this variable is depricated. |
Intel Open Image Denoise – V-Ray's integration of Intel Open Image Denoise. The Intel Open Image denoiser works with your CPU device and does not use hardware acceleration.
