Floatingpagetoc
This page provides information on the Corona Wire Map.
width50%
You can use the Corona Wire Map to visualize the edges and vertices of a 3D object is is applied to. Its typical use is rendering the so called "wires", where the whole scene is shown with visible edges.
width5%
width45%
