This page provides information about the reflection render channel in V-Ray for Blender.
The Reflection Render Channel stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their materials contain no information in the render pass and, therefore, render black.
The Reflection Render Channel is formed by multiplying the Raw Reflection Render Channel by the Reflection Filter Render Channel. So, while the raw reflection pass gives the full reflection of objects reflecting in the scene, the reflection filter sets how much of that reflection should come through in the composite. The two are multiplied together to create the V-Ray Reflection render channel, which gives a true representation of the reflection in the scene.
The Reflection Render Channel is a key component in the main Beauty Pass.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray Reflection
Properties
Enable Deep Output – Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
