« Previous Version 13 Current »
This page provides information about the Specular Render Element in V-Ray for Cinema 4D.
The Specular Render Element is an image that stores specular reflection (basically put, highlight) information calculated from the material's reflection value in the scene. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection, which is reflected at many angles.
The brighter the area, the more highlight reflection the object exhibits in the render. If the Reflection Color parameter of a material is colored, the Specular highlights will be colored.
This render channel can be used to enhance specular reflections; see the example.
UI Path: ||V-Ray|| > Render Elements > Specular
(How to add a render element to a scene)
beauty render Before image
specular channel After image
Properties
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
Example: Enhancing Specular Reflections
In this example, the specular reflections of the foliage are enhanced after rendering using the Specular Render Element. The greenery is selected using a Cryptomatte mask, and its specular reflections are boosted and tinted.
before Before image
after After image
