Version 1 Next »
The Self Illumination Render Element stores the illumination of any self-illuminated materials in the scene.
Page Contents
The Self Illumination Render Element isolates any objects with Self-Illumination enabled in their V-Ray Material. This render element is useful for brightening or color-correcting self-illuminated materials in the final composite.
For example, the material VRayMtl has a parameter for self-illumination. If this parameter is set to a non-black color value, this render element will show the results of the self-illumination.
UI Path: ||Toolbar|| > V-Ray Menu icon > Render > VRayRenderElement > Type: Self Illum
Properties
The Self Illum render element has no controllable properties.
  • This element contains only the light geometry itself, not the light emitted from it. Lighting information is contained in the Lighting Render Elements.
