« Previous Version 4 Next »
This page provides information on rendering with V-Ray for SketchUp.
Both V-Ray and V-Ray GPU engines support Production and Interactive Rendering modes. The Production Rendering mode utilizes all V-Ray's features and is intended to be used to create a clean production ready render.
The Interactive Rendering mode is a fast active renderer that can update the rendering as you make changes to the scene. The Interactive Renderer allows for rendering in the Viewport, where the render output overlays on top of SketchUp's viewport. With Viewport rendering, the scene is rendered interactively and if changes are made, the rendered result is updated.
The Interactive renderer always runs in Progressive mode, a progressive image sampling mode that refines the details over time. The Production rendering mode allows you to switch on/off the Progressive Rendering mode. Switching off the Progressive image sampler automatically activates the Bucket image sampler, which takes a variable number of samples per pixel depending on the difference in the intensity of the pixel.
GPU Rendering
GPU rendering allows V-Ray to perform raytracing calculations on the GPUs installed in the system. Find out more: GPU Rendering
V-Ray Interactive Production Rendering (IPR) provides interactive rendering using the V-Ray and V-Ray GPU renderers. Find out more: Interactive Rendering
Viewport Rendering
Viewport Rendering (VPR) is a render output overlay on top of SketchUp's viewport. With Viewport Rendering, the scene is rendered interactively and if changes are made, the rendered result is updated. Find out more: Interactive Rendering
Batch Rendering
Batch Rendering allows for scenes to be set with tabs and rendered with one button. Find out more: Batch Rendering
Rendering in Chaos Cloud
V-Ray for SketchUp provides in-built integration with Chaos Cloud, allowing you to submit render jobs to the cloud directly from SketchUp. Find out more: Rendering in Chaos Cloud
V-Ray Swarm Rendering
V-Ray Swarm controls V-Ray Distributed Rendering on each render node machine; the actual rendering is handled by V-Ray Standalone. Find out more: V-Ray Swarm Rendering
