©BBB3viz
« Previous Version 7 Next »
This page gives information about the Unclamped Color Render Element.
The Unclamped Color Render Element is a color image that shows the original colors that were clamped. This render element is useful in the compositing process for enhancing extreme colors (very bright or very dark) or for shading the final image with the unclamped colors.
||Render Setup window||  > Render Elements  tab  > Add  button  > VRayUnclampedColor
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Add background – When enabled, adds the background to the render element.
Examples
Unclamped Color Render Element (with add background disabled)
Beauty Composite Render
Composite using Unclamped Color, made warmer
