This page provides information on the V-Ray Light Lister window.
The V-Ray Light Lister window provides an easy way to modify common attributes of all of the lights in the scene.
General Light Lister Parameters
Refresh – Updates the listed lights if lights have been added or removed from the scene.
Isolate – When enabled, isolates a single light for IPR. The isolated light is on in the scene, while all other lights are turned off. See the Example below.
Enable – Enables the light in the scene. See the Example below.
Color – Specifies a color for the light.
Intensity – Specifies the intensity of the light.
Invisible – When enabled, the shape of the light source is invisible in the rendered image.
Examples
Isolate option
Enable option
