Lights
Native name | V-Ray plugin name | Support |
POINT | ||
Spherical | LightSphere | |
Hemispherical | LightRectangle | |
Spot | LightSpotMax | |
IES | LightIESMax | |
LINE | ||
Spherical | LightRectangle | |
Spot | LightRectangle | |
RECTANGLE | ||
CIRCLE | ||
IES | LightIESMax |
Camera
UI | Native name | V-Ray plugin name | Support |
V-Ray Camera | CameraPhysical | ||
Mode: Standard VR Spherical Panorama VR Cubemap |
SettingsCamera/type=0 SettingsCamera/type=9 SettingsCamera/type=10 |
Stereo: Side-by-side Top-bottom | RenderView/stereo_on
Exposure (EV) | combination of ISO, f_number, shutter_speed | ||
Exposure (EV) Auto | SettingsCamera/auto_exposure | ||
White Balance | white_balance | ||
White Balance Auto | SettingsCamera/auto_white_balance | ||
Focus Source: Fixed Distance Fixed Point |
Focus Distance | focus_distance | ||
Defocus | combination of ISO, f_number | ||
Vignetting | vignetting |
Geometry
Native Name | V-Ray Plugin Name | Support |
V-Ray Displacement | GeomDisplacedMesh | |
V-Ray Fur | GeomHair | |
V-Ray Proxy | GeomMeshFile | |
V-Ray Scene | VRayScene |
Materials
Bump
| BRDFBump
Car Paint
| BRDFCarPaint
Hair | BRDFHair3 | |
Blend | BRDFLayered |
Emissive | BRDFLight | |
VRscan | BRDFScanned | |
Subsurface Scattering | BRDFSSS2Complex | Scatter Color is not supported |
Generic | BRDFVRayMtl | |
PBR | BRDFVRayMtl | |
Two Sided | Mtl2Sided | |
Override | MtlOverride | |
Toon Material | MtlToon | |
Wrapper | MtlWrapper |
The table below lists the AutoGen materials (native Revit materials automatically converted to V-Ray ones).
Layered | BRDFLayered | |
Glazing | BRDFVRayMtl | |
Metal | BRDFVRayMtl | |
Opaque | BRDFVRayMtl | |
Transparent | BRDFVRayMtl |
VRayMtl
UI | Native name | V-Ray plugin Name (plugin/parameter) | Support |
Generic | BRDFVRayMtl | ||
Diffuse Color | diffuse | ||
Diffuse Color Texture | diffuse | ||
Diffuse Roughness | roughness | ||
Diffuse Roughness Texture | roughness | ||
Reflection Color | reflect | ||
Reflection Color Texture | reflect | ||
Reflection Glossiness | reflect_glossiness | ||
Reflection Glossiness Texture | reflect_glossiness | ||
Fresnel | fresnel | ||
Reflection IOR | fresnel_ior | ||
Reflection IOR Texture | fresnel_ior | ||
Metalness | metalness | ||
Metalness Texture | metalness | ||
GGX Tail Falloff | gtr_gamma | ||
Surface Control: Use Glossiness Use Roughness |
option_use_roughness=0 option_use_roughness=1 |
BRDF Type: Phong Blinn Ward Microfacet GTR (GGX) |
brdf_type=0 brdf_type=1 brdf_type=2 brdf_type=4 |
Back Side Reflect | option_reflect_on_back | ||
Max Depth | reflect_depth | ||
Affect Channels: Color only Color+alpha All Channels |
reflect_affect_alpha=0 reflect_affect_alpha=1 reflect_affect_alpha=2 |
Trace Reflections | reflect_trace | ||
Anisotropy(-1 to 1) | anisotropy | ||
Anisotropy Texture | anisotropy | ||
Rotation | anisotropy_rotation | ||
Rotation Texture | anisotropy_rotation | ||
Derivation: Local axis Map channel |
anisotropy_derivation=0 anisotropy_derivation=1 |
Local Axis: X Y Z | anisotropy_axis=0 anisotropy_axis=1 anisotropy_axis=2 |
Map Channel/Set | anisotropy_uvwgen | ||
Dim Distance enabled | reflect_dim_distance_on | ||
Dim Distance | reflect_dim_distance | ||
Dim Falloff | reflect_dim_distance_falloff | ||
| Refraction Color | refract | |
Refraction Color Texture | refract | ||
Fog Color | fog_color | ||
Fog Color Texture | fog_color | ||
Fog Multiplier | fog_mult | ||
Fog Bias | fog_bias | ||
IOR | refract_ior | ||
IOR Texture | refract_ior | ||
Refraction Glossiness | refract_glossiness | ||
Refraction Glossiness Texture | refract_glossiness | ||
Affect Shadows | refract_affect_shadows | ||
Fog Units Scaling | fog_unit_scale_on | ||
Max depth | refract_depth | ||
refract_affect_alpha=0 refract_affect_alpha=1 refract_affect_alpha=2 |
Trace Refractions | refract_trace | ||
Dispersion | dispersion_on | ||
Abbe | dispersion | ||
| Fog Scattering | translucency | |
Type: Hard (wax) model Hybrid Back-side Color Scatter Coeff Thickness Light Multiplier |
translucency=1 translucency=3 translucency_color translucency_scatter_coeff translucency_thickness translucency_light_mult |
Back-side Color | translucency_color | ||
Back-side Color Texture | translucency_color | ||
Scatter Coeff | translucency_scatter_coeff | ||
Fwd/back Coeff | translucency_scatter_dir | ||
Thickness | translucency_thickness | ||
Light Multiplier | translucency_light_mult | ||
Coat Amount | coat_amount | ||
Coat Amount Texture | coat_amount | ||
Coat Color | coat_color | ||
Coat Color Texture | coat_color | ||
Coat Glossiness | coat_glossiness | ||
Coat Glossiness Texture | coat_glossiness | ||
Coat IOR | coat_ior | ||
Coat IOR Texture | coat_ior | ||
Coat Bump Enabled | coat_bump_lock | ||
Coat Bump Mode: Bump Map Bump Texture Channel Normal Map |
coat_bump_type=0 coat_bump_type=5 coat_bump_type=1 |
Coat Bump Map Texture | coat_bump_map | ||
Coat Bump Amount | coat_bump_amount | ||
Coat Bump Amount Texture | coat_bump_amount | ||
Sheen Color | sheen_color | ||
Sheen Color Texture | sheen_color | ||
Sheen Glossiness | sheen_glossiness | ||
Sheen Glossiness Texture | sheen_glossiness | ||
| Opacity | opacity | |
Opacity Texture | opacity | ||
Custom Source: DIffuse Texture Alpha Opacity Texture Alpha |
opacity/TexCombineFloat opacity/TexAColorChannel/mode=3 |
Mode: Normal Clip Stochastic |
opacity_mode=0 opacity_mode=1 opacity_mode=2 |
Bump Mode: Bump Map Normal Map |
bump_type=0 bump_type=1 |
Bump Map Texture | bump_map | ||
Bump Amount | bump_amount | ||
Bump Amount Texture | bump_amount | ||
Mode: Multiply Blend amount |
TexCombineColor/color TexCombineColor/texture_multiplier | | |
Color | diffuse/TexCombineColor/texture_multiplier | ||
Reflection Color | reflect/TexCombineColor/texture_multiplier | ||
Reflection Glossiness | reflect_glossiness/TexCombineColor/texture_multiplier | ||
Refraction Color | refract/TexCombineColor/texture_multiplier | ||
IOR | refract_ior/TexCombineColor/texture_multiplier | ||
Refraction Glossiness | refract_glossiness/TexCombineColor/texture_multiplier | ||
Opacity | opacity/TexCombineColor/texture_multiplier | ||
| Color | color | |
Color Texture | color | ||
Intensity | colorMultiplier | ||
Intensity Texture | colorMultiplier | ||
Transparency | transparency | ||
Transparency Texture | transparency | ||
Emit On Back Side | doubleSided | ||
Compensate EV | compensateExposure | ||
Color*Opacity | multiplyByOpacity | ||
Mode: Multiply Blend amount | TexCombineColor/color TexCombineColor/texture_multiplier |
Color | TexCombineColor | ||
Intensity | TexCombineColor | ||
Transparency | TexCombineColor | ||
Bump | BRDFBump | ||
| Base | base_brdf | |
Map: Bump Map Bump Texture Channel Normal Map | bump_tex_color map_type=0 map_type=5 map_type=1 | ||
Normal Map Type: Tangent Space Object Space Screen Space World Space |
map_type=1 map_type=2 map_type=3 map_type=4 |
Amount | bump_tex_mult_tex | ||
Delta Scale | bump_delta_scale |
Maps
UI | Native name | V-Ray Plugin Name | Support |
Bitmap | TexBitmap | ||
Color | TexAColor | ||
Temperature | TexTemperature | ||
Gradient | TexRamp | ||
Color Correction | ColorCorrection | ||
Spline Curve | TexRemap | ||
Bezier Curve | TexBezierCurveColor | ||
Simple Mix | TexCombineColor | ||
Mix (Value) | TexBlend | ||
Mix (Operator) | TexCompMax | ||
Mix (Map) | TexMix | ||
Multi-Sub | |||
Tri-Planar | TexTriPlanar | ||
Checker | TexChecker | ||
Grid | TexGrid | ||
Tiles | TexTiles | ||
Cloth | TexCloth | ||
Leather | TexLeather | ||
Bulge | TexBulge | ||
UVW | TexUVW | ||
Water | TexWater | ||
Noise A | TexNoise | ||
Noise B | TexNoiseMax | ||
Cellular | TexCellular | ||
Marble | TexMarble | ||
Splat | TexSplat | ||
Smoke | TexSmoke | ||
Stucco | TexStucco | ||
Rock | TexRock | ||
Granite | TexGranite | ||
Speckle | TexSpeckle | ||
Edges | TexEdges | ||
Falloff | TexFalloff | ||
Fresnel | TexFresnel | ||
Curvature | TexCurvature | ||
Dirt | TexDirt |
Geometry
Revit | Support |
Revit families replaced with .vrmesh | |
Native Revit RPCs will render as grey planes | |
Revit families replaced with a .vrscene | |
Infinite Ground Plane | |
Fur | |
Displacement |
