This page provides information about the caustics render channel in V-Ray for Blender.
Caustics is an effect that is produced when light rays are reflected or refracted by the materials within a scene, which can produce light patterns on objects in the scene. The Caustics Render Channel displays these effects, generated with Caustics photon mapping. It is enabled from the Caustics Rollout rollout under the GI tab in the Render Settings window. This render channel is useful for enhancing or toning down caustic effects in the composite.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray Caustics
Properties
See the Render Channels page to find out where you can find these properties.
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping  Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Filtering –  Applies an image filter to this channel.
