« Previous Version 8 Next »
This page provides information about the Outline Override material in V-Ray for Revit.
The Outline Override material is related to the global Outline settings and some of the global options affect all Outline Override materials.
The Outline Override material is available only when the engine is set to CPU. It is currently not supported for GPU.
Outline materials from previous V-Ray versions will be automatically migrated to Outline Override materials.
UI Options
The Outline Override material settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button under the Preview Swatch.
An Add Layer and Add Attribute buttons are provided for some V-Ray materials, including Outline Override. You can select an additional layer that can add up to the appearance of the material. For more information, see the Layers section and the Attributes section.
Holding down Ctrl while having the Add Attribute or Add Layer menu open, allows selecting multiple entries without closing the dropdown.
The context menu of the Color slot provides options to Copy and Paste, as well as to Reset the color.
A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
Base – Specifies the material on top of which the Outline effect is applied.
Outline
Line Color Specifies the color of the outlines. If a texture is selected, it overrides the color as long as the texture checkbox is enabled. See the Lines Color example below.
OpacitySpecifies how transparent or opaque the outlines are. A texture map can be used for this channel.
Normal Threshold – Determines when lines will be created for parts of the same object with varying surface normals (e.g. at the inside edges of a box). A value of 0.0 means that only 90 degrees or larger angles generate internal lines. Higher values mean that smoother transitions between face normals can also generate a line. Setting this value to 1.0 fills curved objects completely.
Overlap Threshold – Determines when outlines will be created for overlapping parts of the one and the same object . Lower values reduce the internal overlapping lines, while higher values produce more overlap lines. Setting this value to 1.0 fills curved objects completely.
Width – Specifies the width of the outlines. See the Line Width example below.
Example: Line Width
This example shows the effect of the Width parameter. The Inner Line Control is disabled.
Width = 0
Width = 0.5
Width = 1
Width = 1.5
Width = 2
Inner Line Control
Enables a separate control for the inner edges. See the Inner Line Control example below.
Inner Line Color – Specifies the color of the inner lines. See the Lines Color example below.
Inner Width – Specifies the width of the inner lines.
Some of the global parameters have an effect on all materials with Outline attribute. These parameters are Width Type, Trace Bias, Hide Inner Lines, Visible in Reflections/Refractions, and Compensate EV.
Example: Inner Line Control
This example shows the effect of the Inner Line Control parameter. The main lines are black and the Inner Lines are red. The Width of the main lines is set to 3, while that of the Inner Lines is set to the default 1.5.
off
on
Example: Line Color
This examples shows the effect of the Line Color and Inner Line Color parameters.
Line Color is red, Inner Lines are disabled.
Line Color is red, Inner Line Color is black
Line Color is green, Inner Line Color is blue
Override Control
Can be Overridden – When enabled, the material can be overridden when you enable the Opaque override option in the Global Overrides tab of Appearance Manager.
Attributes
The Attributes available for the Outline Override material are as follows.
Translucency
MultiExcerpt named Translucency Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Bump
MultiExcerpt named Bump Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Outline
MultiExcerpt named Outline Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Displacement
MultiExcerpt named Displacement Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Raytrace Properties
MultiExcerpt named Raytrace Properties Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Override
MultiExcerpt named Override Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Material ID
MultiExcerpt named Material ID Attribute was not found -- Please check the page name and MultiExcerpt name used in the MultiExcerpt-Include macro
Layers
The Layers available for the Outline Override material are as follows.
VRay Mtl
Emissive
Diffuse Coat
Reflective Coat
Flakes 2
Stochastic Flakes
