Square Enix © Goodbye Kansas
« Previous Version 3 Current »
This page provides information on the supported feateres with MaterialX in V-Ray for Maya.
MaterialX is an open-source standard for representing shading networks. MaterialX shading networks can be used across different applications and renderers.
V-Ray offers the VRayMaterialX node that loads .mtlx files to render.
Supported Nodes
Category
MtlX Shader Name
Node Name
USD id
V-Ray Plugin
Support
Adjustment
MtlX Adjust as HSV
mtlxhsvadjust
ND_hsvadjust
(tick)
MtlX Contrast
mtlxcontrast
ND_contrast
TexMayaContrast
(tick)
MtlX Curveadjust
mtlxcurveadjust
ND_curveadjust
(error)
MtlX HSV to RGB
mtlxhsvtorgb
ND_hsvtorgb
(tick)
MtlX Luminance
mtlxluminance
ND_luminance
TexLuminance
(tick)
MtlX Range
mtlxrange
ND_range
(tick)
MtlX Remap
mtlxremap
ND_remap
TexSetRange / TexRemapFloat
(tick)
MtlX RGB to HSV
mtlxrgbtohsv
ND_rgbtohsv
(tick)
MtlX Saturate
mtlxsaturate
ND_saturate
(tick)
MtlX Smoothstep
mtlxsmoothstep
ND_smoothstep
(tick)
Application
MtlX Frame
mtlxframe
ND_frame_float
TexSampler
(tick)
MtlX Time
mtlxtime
ND_time_float
multiple
(tick)
Channel
MtlX Combine2
mtlxcombine2
ND_combine2
(tick)
MtlX Combine3
mtlxcombine3
ND_combine3
TexRgbaCombine
(tick)
MtlX Combine4
mtlxcombine4
ND_combine4
TexRgbaCombine
(tick)
MtlX Convert
mtlxconvert
ND_convert
multiple
(tick)
MtlX Extract
mtlxextract
ND_extract
TexAColorChannel
(tick)
MtlX Separate2
mtlxseparate2
ND_separate2
(tick)
MtlX Separate Color 3
mtlxseparate3c
ND_separate3
TexAColorOp
(tick)
MtlX Separate Vector 3
mtlxseparate3v
ND_separate3
TexAColorOp
(tick)
MtlX Separate Color 4
mtlxseparate4c
ND_separate4
TexAColorOp
(tick)
MtlX Separate Vector 4
mtlxseparate4v
ND_separate4
TexAColorOp
(tick)
MtlX Swizzle
mtlxswizzle
ND_swizzle
(tick)
Compositing
MtlX Burn
mtlxburn
ND_burn
multiple
(tick)
MtlX Difference
mtlxdifference
ND_difference
multiple
(tick)
MtlX Disjoint Over
mtlxdisjointover
ND_disjointover
multiple
(tick)
MtlX Dodge
mtlxdodge
ND_dodge
multiple
(tick)
MtlX In
mtlxin
ND_in
multiple
(tick)
MtlX Inside
mtlxinside
ND_inside
TexMaskMax
(tick)
MtlX Mask
mtlxmask
ND_mask
multiple
(tick)
MtlX Matte
mtlxmatte
ND_matte
multiple
(tick)
MtlX Minus
mtlxminus
ND_minus
multiple
(tick)
MtlX Mix
mtlxmix
ND_mix
TexMix
(tick)
MtlX Out
mtlxout
ND_out
multiple
(tick)
MtlX Outside
mtlxoutside
ND_outside
TexMaskMax
(tick)
MtlX Over
mtlxover
ND_over
multiple
(tick)
MtlX Overlay
mtlxoverlay
ND_overlay
multiple
(tick)
MtlX Plus
mtlxplus
ND_plus
multiple
(tick)
MtlX Premult
mtlxpremult
ND_premult
(error)
MtlX Screen
mtlxscreen
ND_screen
multiple
(tick)
MtlX Un-Premult
mtlxunpremult
ND_unpremult
(tick)
Conditional
MtlX If Equal
mtlxifequal
ND_ifequal
TexCondition2
(tick)
MtlX If Greater
mtlxifgreater
ND_ifgreater
TexCondition2
(tick)
MtlX If Greater or Equal
mtlxifgreatereq
ND_ifgreatereq
TexCondition2
(tick)
MtlX Switch
mtlxswitch
ND_switch
TexMulti
(tick)
Convolution2D
MtlX Blur
mtlxblur
(tick)
MtlX Height to Normal
mtlxheighttonormal
ND_heighttonormal
(tick)
Geometric
MtlX Bitangent
mtlxbitangent
ND_bitangent
(error)
MtlX Geometry Color
mtlxgeomcolor
ND_geomcolor
TexUserColor
(tick)
MtlX Geometry Property Value
mtlxgeompropvalue
ND_geompropvalue
multiple
(tick)
MtlX Normal
mtlxnormal
ND_normal_vector3
TexSampler
(tick)
MtlX Position
mtlxposition
ND_position_vector3
TexSampler
(tick)
MtlX Tangent
mtlxtangent
ND_tangent_vector3
(tick)
MtlX Texcoord
mtlxtexcoord
ND_texcoord_vector3
(tick)
Global
MtlX Ambient Occlusion
mtlxambientocclusion
ND_ambientocclusion_float
TexDirt
(error)
Houdini
MtlX Bias
hmtlxbias
ND_hmtlxbias_float
(error)
MtlX Facing Ratio
hmtlxfacingratio
ND_hmtlxfacingratio_float
(error)
MtlX Gain
hmtlxgain
ND_hmtlxgain_float
(error)
MtlX Hcatmullrom
hmtlxhcatmullrom
ND_hcatmullrom
(error)
MtlX Hinvlinear
hmtlxhinvlinear
ND_hinvlinear_float
(tick)
MtlX Huniformcubic
hmtlxhuniformcubic
ND_huniformcubic
(tick)
MtlX Huniformramp
hmtlxhuniformramp
ND_huniformramp
(tick)
Light
MtlX Directional Light
mtlxdirectional_light
(error)
MtlX Point Light
mtlxpoint_light
(error)
MtlX Spot Light
mtlxspot_light
(error)
Material
MtlX Surface Material
mtlxsurfacematerial
(error)
MtlX Volume Material
mtlxvolumematerial
(error)
Procedural
MtlX Color Cubic Ramp
hmtlxcubicrampc
multiple
(error)
MtlX Color Ramp
hmtlxrampc
multiple
(error)
MtlX Constant
mtlxconstant
ND_constant
multiple
(tick)
MtlX Float Cubic Ramp
hmtlxcubicrampf
multiple
(error)
MtlX Float Ramp
hmtlxrampf
multiple
(error)
Procedural2D
MtlX Cell Noise 2D
mtlxcellnoise2d
ND_cellnoise2d_float
multiple
(tick)
MtlX Noise2D
mtlxnoise2d
ND_noise2d
TexNoiseMaya
(tick)
MtlX Ramp4
mtlxramp4
ND_ramp4
TexRamp
(tick)
MtlX Ramplr
mtlxramplr
ND_ramplr
TexRamp
(tick)
MtlX Ramptb
mtlxramptb
ND_ramptb
TexRamp
(tick)
MtlX Splitlr
mtlxsplitlr
ND_splitlr
(tick)
MtlX Splittb
mtlxsplittb
ND_splittb
(tick)
MtlX Worley Noise 2D
mtlxworleynoise2d
ND_worleynoise2d
(tick)
Procedural3D
MtlX Cell Noise 3D
mtlxcellnoise3d
ND_cellnoise3d_float
multiple
(tick)
MtlX Fractal3D
mtlxfractal3d
ND_fractal3d
(tick)
MtlX Noise3D
mtlxnoise3d
ND_noise3d
(tick)
MtlX Worley Noise 3D
mtlxworleynoise3d
ND_worleynoise3d
(tick)
Texture2D
MtlX Image
mtlximage
ND_image
multiple
(tick)
MtlX Tiled Image
mtlxtiledimage
ND_tiledimage
multiple
(tick)
Texture3D
MtlX Triplanar Projection
mtlxtriplanarprojection
ND_triplanarprojection
(tick)
Math
MtlX Absval
mtlxabsval
ND_absval
TexFloatOp / TexAColorOp
(tick)
MtlX Acos
mtlxacos
ND_acos
multiple
(tick)
MtlX Add
mtlxadd
ND_add
(tick)
MtlX Array Append
mtlxarrayappend
ND_arrayappend
(error)
MtlX Asin
mtlxasin
ND_asin_float
multiple
(tick)
MtlX Atan2
mtlxatan2
ND_atan2_float
multiple
(tick)
MtlX Ceil
mtlxceil
ND_ceil_float
multiple
(tick)
MtlX Clamp
mtlxclamp
ND_clamp
TexClamp
(tick)
MtlX Cos
mtlxcos
ND_cos
multiple
(tick)
MtlX Cross Product
mtlxcrossproduct
ND_crossproduct_vector3
TexVectorOp
(tick)
MtlX Determinant
mtlxdeterminant
ND_determinant
(tick)
MtlX Divide
mtlxdivide
ND_divide
multiple
(tick)
MtlX Dot Product
mtlxdotproduct
ND_dotproduct_vector3
TexVectorOp
(tick)
MtlX Exp
mtlxexp
ND_exp
multiple
(tick)
MtlX Floor
mtlxfloor
ND_floor
multiple
(tick)
MtlX Invert
mtlxinvert
ND_invert
(tick)
MtlX Invert Matrix
mtlxinvertmatrix
(tick)
MtlX Ln
mtlxln
ND_ln
multiple
(tick)
MtlX Magnitude
mtlxmagnitude
ND_magnitude
multiple
(tick)
MtlX Max
mtlxmax
ND_max
(tick)
MtlX Min
mtlxmin
ND_min
(tick)
MtlX Modulo
mtlxmodulo
ND_modulo
(tick)
MtlX Multiply
mtlxmultiply
ND_multiply
(tick)
MtlX Normalize
mtlxnormalize
ND_normalize
TexVectorProduct
(tick)
MtlX Normalmap
mtlxnormalmap
ND_normalmap
(tick)
MtlX Place2D
mtlxplace2d
ND_place2d_vector2
(tick)
MtlX Power
mtlxpower
ND_power
(tick)
MtlX Rotate2D
mtlxrotate2d
ND_rotate2d_vector2
(tick)
MtlX Rotate3D
mtlxrotate3d
ND_rotate3d_vector3
(tick)
MtlX Sign
mtlxsign
ND_sign
multiple
(tick)
MtlX Sin
mtlxsin
ND_sin
multiple
(tick)
MtlX Sqrt
mtlxsqrt
ND_sqrt
multiple
(tick)
MtlX Subtract
mtlxsubtract
ND_subtract
(tick)
MtlX Tan
mtlxtan
ND_tan
multiple
(tick)
MtlX Transform Matrix
mtlxtransformmatrix
ND_transformmatrix
(tick)
MtlX Transform Normal
mtlxtransformnormal
ND_transformnormal_vector3
(error)
MtlX Transform Point
mtlxtransformpoint
ND_transformpoint_vector3
(error)
MtlX Transform Vector
mtlxtransformvector
ND_transformvector_vector3
(error)
MtlX Transpose
mtlxtranspose
ND_transpose
(tick)
Pbr
MtlX Blackbody
mtlxblackbody
ND_blackbody
(error)
