« Previous Version 14 Next »
 Alligator noise
Simplex noise
Perlin flow noise
Simplex flow noise
Alligator noise
This is an implementation of the Houdini's Alligator noise as described here.
It is a 3D noise that uses the shading point's position in object space rather than the surface's texture coordinates.
Use this shader with a VRayOSLTex instance with the "wrap texture coordinates" option turned off.
The shader code can be found at alligatornoise.zip.
start frequency - Initial sampling position multiplier that affects the overall granularity.
start offset - Offsets the initial sampling position effectively shifting the pattern in the specified direction.
lacunarity - Position (frequency) multiplier per iteration.
gain - Amplitude multiplier per iteration.
octaves - Number of fractal iterations.
attenuation - The power of the falloff applied to the final result.
Shader code
Here is the shader code:
alligatornoise.osl
 * Copyright (c) 2016
 *	Side Effects Software Inc.  All rights reserved.
 * Redistribution and use of Houdini Development Kit samples in source and
 * binary forms, with or without modification, are permitted provided that the
 * following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. The name of Side Effects Software may not be used to endorse or
 *    promote products derived from this software without specific prior
 *    written permission.
 * THIS SOFTWARE IS PROVIDED BY SIDE EFFECTS SOFTWARE `AS IS' AND ANY EXPRESS
 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN
 * NO EVENT SHALL SIDE EFFECTS SOFTWARE BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
 * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
 * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
 * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/// Alligator Noise is provided by Side Effects Software Inc. and is licensed
/// under a Creative Commons Attribution-ShareAlike 4.0 International License.
/// Author:  "Side Effects Software Inc"
/// Source:  "http://www.sidefx.com/docs/hdk15.0/alligator_2alligator_8_c-example.html"
/// License: "http://creativecommons.org/licenses/by-sa/4.0/"
/// Translated and modified by Ivan Mavrov, Chaos Group Ltd. 2016
/// Contact: ivan.mavrov@chaosgroup.com
/// 3D Alligator noise implementation.
/// Returned values are in the [0, 1] range.
float alligatorNoise3D(point position) {
	vector cellOffsets[27] = {
		vector( 0,  0,  0),
		vector( 1,  0,  0),
		vector( 1,  1,  0),
		vector( 0,  1,  0),
		vector(-1,  1,  0),
		vector(-1,  0,  0),
		vector(-1, -1,  0),
		vector( 0, -1,  0),
		vector( 1, -1,  0),
		vector( 0,  0, -1),
		vector( 1,  0, -1),
		vector( 1,  1, -1),
		vector( 0,  1, -1),
		vector(-1,  1, -1),
		vector(-1,  0, -1),
		vector(-1, -1, -1),
		vector( 0, -1, -1),
		vector( 1, -1, -1),
		vector( 0,  0,  1),
		vector( 1,  0,  1),
		vector( 1,  1,  1),
		vector( 0,  1,  1),
		vector(-1,  1,  1),
		vector(-1,  0,  1),
		vector(-1, -1,  1),
		vector( 0, -1,  1),
		vector( 1, -1,  1)
	point iPosition = floor(position);
	float firstReverseSmoothPointDistance = 0.0;
	float secondReverseSmoothPointDistance = 0.0;
	for (int cellIndex = 0; cellIndex < 27; ++cellIndex) {
		point cellOrigin = iPosition + cellOffsets[cellIndex];
		vector cellPointOffset = cellnoise(cellOrigin, 0.0);
		point cellPointPosition = cellOrigin + cellPointOffset;
		float cellPointDistance = distance(position, cellPointPosition);
		if (cellPointDistance < 1.0) {
			float reverseSmoothDistance = smoothstep(0.0, 1.0, 1.0 - cellPointDistance);
			float distanceMultiplier = float(cellnoise(cellOrigin, 1.0));
			reverseSmoothDistance *= distanceMultiplier;
			if (firstReverseSmoothPointDistance < reverseSmoothDistance) {
				secondReverseSmoothPointDistance = firstReverseSmoothPointDistance;
				firstReverseSmoothPointDistance = reverseSmoothDistance;
			} else {
				if (secondReverseSmoothPointDistance < reverseSmoothDistance) {
					secondReverseSmoothPointDistance = reverseSmoothDistance;
	return firstReverseSmoothPointDistance - secondReverseSmoothPointDistance;
/// 3D Fractal Alligator noise implementation.
/// Returned values are in the [-1, 1] range.
float fractalAlligatorNoise3D(
	point position,
	float lacunarity, // Houdini 2.0
	float gain,       // Houdini rough
	int octaveCount   // Houdini turbulence - 1
	float noiseValue = 0.0;
	float amplitude = 1.0;
    for (int octave = 0; octave < octaveCount; ++octave) {
		noiseValue += amplitude * (alligatorNoise3D(position) - 0.5);
		position *= lacunarity;
		amplitude *= gain;
	return noiseValue;
shader FractalAlligatorNoise
	[[ string description = "Fractal Alligator noise" ]]
	float start_frequency = 1.0
		[[ string description = "Initial sampling position multiplier that affects the overall granularity." ]],
	vector start_offset = vector(0.0)
		[[ string description = "Offsets the initial sampling position effectively shifting the pattern in the specified direction." ]],
	float lacunarity = 2.0
		[[ string description = "Position (frequency) multiplier per iteration." ]],
	float gain = 0.5
		[[ string description = "Amplitude multiplier per iteration." ]],
	int octaves = 8
		[[ string description = "Number of fractal iterations." ]],
	float attenuation = 1.0
		[[ string description = "The power of the falloff applied to the final result." ]],
	output color result = 0.0
	point objectPosition = transform("object", P);
	point startPosition = start_frequency * objectPosition - start_offset;
	float noiseValue = fractalAlligatorNoise3D(startPosition, lacunarity, gain, octaves);
	noiseValue = 0.5 * noiseValue + 0.5;
	noiseValue = pow(noiseValue, attenuation);
	result = color(noiseValue);
Simplex noise
Perlin flow noise
Simplex flow noise
