Version 1 Next »
This page provides information about the Chaos Improvement Program in Corona for Cinema 4D.
The Chaos Improvement Program is based on telemetry. It allows Chaos to track general usage statistics. The type of information collected includes the parameter values that people use most often, which will enable Chaos to optimize and improve the performance of Corona. No intelligence property is violated.
Enable Chaos Telemetry
Once Corona for Cinema 4D is successfully installed, you are invited to participate in the Chaos Improvement Program. By choosing to participate you can contribute to the improvement decisions for the future versions of Corona.
Your participation involves sharing anonymized telemetry, with the option to enable personalized telemetry too.
With Anonymized Telemetry, you share data on frequently used features and parameter values without any personally identifiable information. With Personalized Telemetry, you share the same data as with Anonymized Telemetry, along with information tied to your user license, enabling Chaos to further optimize the product for your specific use.
Chaos Telemetry Settings
You can change the telemetry settings directly in Cinema 4D at any time after installing Corona. The Usage Data settings can be found in the Preferences window > Renderer > Corona. You can access the Corona Renderer Preferences through the Corona menu > Preferences. Alternatively, you can access the Preferences through the Edit menu > Preferences
Enabling the Send Product usage data (takes effect after Cinema 4D restart) option launches the Chaos Improvement Program for Corona.
