This page provides information about Chaos Bridge for Rhino.
Chaos Bridge is a compatibility plugin for Rhino. Its main feature is its ability to export V-Ray scenes that can make their way into other Chaos products such as rendering integrations in other DCCs as well as standalone applications and services. The export of V-Ray scenes is available without a license.
Enscape and V-Ray data are exported following the V-Ray for Rhino logic. To edit this data, install the corresponding Chaos plugin used for authoring it.
If you already use V-Ray for Rhino and have it installed, you don't need to install Chaos Bridge. V-Ray for Rhino is already fully capable of exporting vrscenes.
