This page provides information about the User Color utility texture in V-Ray for Blender.
The V-Ray User Color texture can be used to read user-defined object properties from the current material and convert them to a color value. This allows you to use the same shading network on several different objects in the scene but to control various aspects of the material through user-defined properties. This texture also has the ability to read mesh color sets, UV sets, and extra channel information from VRayProxy objects.
The Example on the right uses V-RayUserColor to control the diffuse value on a single V-Ray Material.
Properties
User Attribute – Specifies the name of the user attribute that is looked up and returned from this shading node.
Default Color – Specifies the color to return if the User Attribute is not found on the shaded object.
