Version 1 Next »
This page provides information about the Specular render channel in V-Ray for Blender.
The Specular Render Channel is an image that stores specular reflection (basically put, highlight) information calculated from the material's reflection value in the scene. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection, which is reflected at many angles.
The brighter the area, the more highlighted reflection the object exhibits in the render. If the Reflection Color parameter of a material is colored, the Specular highlights will be colored.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray Specular
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider For Anti-aliasing – When enabled, anti-aliasing is used where possible.
Denoise – Enables the render element's denoising, provided the Denoiser is enabled.
