« Previous Version 2 Current »
This page provides information about the SSS Render Channel in V-Ray for Blender.
The SSS Render Channel stores information calculated from Subsurface Scattering materials (V-Ray Fast SSS2/V-Ray Mtl) This render channel can then be used to enhance or color-correct just the subsurface scattering component of the image during the compositing process.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray SSS
beauty render Before image
SSS channel After image
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping –
Common Uses
The Subsurface Scattering render channel is useful for changing the appearance of Fast SSS2 elements after rendering in a compositing or image editing software. In the example, the scattering color is changed to red using the SSS2 RC. See the render before and after compositing.
before Before image
after After image
