This page provides details on the V-Ray for Unreal UI and how it is integrated into the Unreal interface.
Page Contents
The V-Ray for Unreal button gives you access to all of the settings and options that are available with V-Ray.
View
This allows you to select which one of the Revit 3D views to render.
Render
Allows you to choose your Render type and open up the V-Ray Frame Buffer.
Quality
Provides a drop down menu with a specific set of presets. The provide preset settings ranging from very low quality “Draft” settings to “Very High Quality” settings.
Resolution
Allows you to choose your Output and Crop Box resolution size.
Lighting
Gives you access to the options for the V-Ray Sun and Sky Blueprint, V-Ray Light Dome Blueprint, No V-Ray Lights and Artificial Lights.
Assets
Gives you access to the V-Ray Asset Browser which contains the Material Map, Global Materials, RPC Proxies and V-Ray Fur settings.
Camera
Gives you access to the V-Ray Camera settings.
Gives you access to the V-Ray Settings.
Opens the online V-Ray for Revit Help documents.
V-Ray
Allows you to acquire your license and gives you access to the Online License Server.
