© Bertrand Benoit
« Previous Version 2 Next »
Page Contents
This page contains notes for each incremental release of V-Ray for Unreal. Currently supported versions versions of Unreal Engine are 4.18.3 and 4.19.
Import of vrscene files with smart translation of materials and lights:
-          Automatic convert of materials and lights into real-time equivalents for UE workflows
-          Keeping original materials from the imported vrscene connected to their real-time versions and are using them for raytraced rendering
Photorealistic raytraced rendering directly from Unreal:
-          Support for VRayMtl material (including partial VRay2SidedMtl)
-          Initial implementation of a PBR material
-          Initial implementation of an easy to use car paint material
-          Support for VRayTriplanarTex
-          Support for VRayLightDome, VRayLightSphere, VRayLightIES, UE Spot light, UE Point light, UE Direct light
-          Initial implementation of the V-Ray Sun&Sky system
-          Support for the VRayPhysicalCamera
-          Support for the 3ds Max’s Physical Camera
-          Initial implementation of exposure and color mapping
-          Support for Brute force and Light cache GI engines
-          Initial implementation of interactive rendering
-          Support for the V-Ray Denoiser
-          Support for the VFB
V-Ray Hybrid rendering on both GPU and CPU:
-          Using the V-Ray Next GPU engine
-          Support for DR
Support for the VR mode in the Unreal Editor
V-Ray materials are supported natively in UE and work with:
-          Lightmass baking
-          Lights
-          Reflection probes
-          Post process materials
-          Blueprints
  • For best results when importing vrscene files make sure your scenes are authored and optimized for V-Ray GPU Next or V-Ray 3.6 GPU.
  • Only Render nodes for V-Ray Next are supported.
