This page gives details on how to install the online license system for Chaos Group products.
Online Licensing System is a secure way to license products online as a highly-encrypted centralized online system that manages licenses for all your systems. Additionally, the Online License System also provides for users to "borrow" licenses from their online accounts and work offline without having a hardware dongle, for up to 14 days at a time. Overview
On the Linux OS, please use your local user with the sudo command instead of the root user to run the installer. 1) Run the License Server installer that is included with the Chaos Group product installation package or download the License Server installer separately from the Downloads section of the Chaos Group website (you'll need to be logged in to access it). If you are installing for the first time, then Activate during installation will be checked. If you have a previous version of the License Server installed and already activated, then this will be unchecked. 4) The installation process will then Check for Running Applications, which may take a few minutes so please be patient. The application may appear to be non-responsive, but it should complete its search for running applications and move on to the next step 5) The license server is then installed on your machine. For Windows, use the Services window For Linux, use SystemV, Upstart or systemd For OSX, use launchctl 7) Enter your credentials, these are the same as your online credentials used to log into your account at my.chaosgroup.com. 8) The installation process is then complete. If you close your browser window, an easy way to reopen the license server page is from the Manage V-Ray Online License Server tool installed with the rest of your Application shortcuts (e.g. Windows Start Menu), which will direct you to http://localhost:30304/ 10) Log in to the Chaos Group Login Portal and enter your credentials. Installation Process
2) Please read over the license agreement. To continue with the installation process, click the I Agree button.
3) You can choose to accept the default installation parameters, or use the Customize button to change these parameters.
Windows Default Install path - C:\Program Files\Chaos Group\VRLService\OLS
Linux Default Install path - /usr/ChaosGroup/VRLService/OLS
OSX Default Install path - /Applications/ChaosGroup/VRLService/OLS
6) The application is registered as a service using one of the init systems available within your machine's OS. Use the appropriate service commands to start and stop the license server.
9) If you are installing for the first time and deselected Activate during installation a browser window will open to the Chaos Group License Server page. Click the ENABLE ONLINE LICENSING link.
For more details on how the Online Licensing System works, please see the Online Licensing page.
