This page provides information on the Anti-Aliasing options in the Sampler tab of the V-Ray Renderer.
Page Contents
In V-Ray, an image sampler refers to an algorithm for calculating a pixel's color based on the colors within and around it.
Each pixel in a rendering can have only one color. To get the color of a pixel, V-Ray calculates it based on the object's material, direct light striking the object, and indirect lighting in the scene. This calculation might seem straightforward, but within a single pixel there might be multiple colors from various objects or parts of a detailed texture, or even different brightnesses on the same object due to changes in object shape or falloff of light sources. The differences between these colors might be subtle or abrupt. If a pixel consists of multiple colors at the sub-pixel level, some work has to be done to determine the best color for that particular pixel in the rendered image.
To determine the best color for an individual pixel, V-Ray can look at (or sample) colors from different parts of the pixel, and even the pixels around it. This process is called image sampling. V-Ray offers two main sampling types for renders: Progressive sampling and Bucket sampling.
Image courtesy of Tuna Unalan
Multiple colors within a single pixel. What color should the pixel be?
UI Path: ||Parameters tab|| > Sampler tab
(with the V-Ray Renderer node selected)
What is Anti-Aliasing?
One of the functions of image sampling is anti-aliasing, which is the reduction of jagged edges in a rendering. The following example shows the basic difference between an image with anti-aliasing, and one without. The left images are jagged around the edges of the sphere, while the right are smooth.
Here we have an example of a gray sphere against a blue background. If only one sample is taken for the each of the pixels around the edge of the sphere, the choice of pixel color is limited to the dark gray at the edge of the sphere, or the blue background. Using one of these colors (ie. taking only one sample) makes the image look jagged around the perimeter of the sphere. This is the equivalent of no anti-aliasing at all.
If two or more samples are taken in each pixel, the colors are averaged, and pixels at the edge of the sphere end up being a color in between the dark gray of the sphere and the blue background. These in-between colors make the sphere appear smoother in the final rendering.
No anti-aliasing (1 sample or subdiv per pixel)
Anti-aliasing on (minimum of -1 and maximum of 2 samples per pixel)
Anti-Aliasing
This section covers common parameters for all sampler types. For parameters that are specific to each sampler, see the following sampler sections below.
Sampler Type – Specifies the image sampler type. Specific parameters for the selected type appear at the bottom of this rollout.
Progressive – Progressively samples the entire image. See the Progressive Sampler for additional parameters.
Bucket – Takes a variable number of samples per pixel depending on the difference in the intensity of the pixels.
Min Shading Rate – Controls the number of primary rays shot for AA (anti-aliasing) versus secondary rays for other effects like glossy reflections, GI, area shadows, etc. Higher values mean that less time will be spent on AA, and more effort will be put in the sampling of shading effects. This approach is especially useful with the Progressive image sampler. Note: Not available when using a GPU-based Production engine.
Render mask – Enables the render mask feature. The render mask allows you to define which pixels of the image are calculated. The rest of the pixels are left intact. This feature works best with the V-Ray frame buffer and the Bucket image sampler. The following types are available:
Disable – The render mask is not used
Objects – A custom set of objects to render can be defined.
Object ID – Only objects with specified Object IDs will be rendered, you can list more than one by using commas to separate them.
For more information, see the Render Mask example below.
Object IDs – Specifies a list of object IDs to be used for the render mask.
Filter Type – Specifies the filter type to be used for anti-aliasing. V-Ray supplies eight types of Anti-aliasing filters: Box, Area, Triangle, Lanczos, Sinc, CatmullRom, Gaussian and Cook Variable. Each has advantages and disadvantages, which make them useful for different tasks. For more information, see the Anti-aliasing Filters example and the Anti-aliasing Filters and Moire Effects example below.
Filter Size – Determines the size of the filter in pixels. Higher values yield blurrier results. For more information, see the Anti-aliasing Filters example and the Anti-aliasing Filters and Moire Effects example below.
Example: Anti-aliasing Filters
Here is an example briefly demonstrating the effect of different anti-aliasing filters on the final result.
Note that rendering with a particular filter is not the same as rendering without a filter and then blurring the image in a post-processing program like Adobe Photoshop. Filters are applied on a sub-pixel level, over the individual sub-pixel samples. Therefore, applying the filter at render time produces a much more accurate and subtle result than applying it as a post effect. The zoomed in images below have been zoomed in and cropped 300%.
Filter | Image | Zoomed-in Image | Comments |
Filtering is off. | Applies an internal 1x1 pixel box filter. | ||
Lanczos filter size 2.0 | |||
Triangle Filter size 2.5 | |||
Sinc Filter size 2.5 | |||
Box Filter size 2.5 | |||
Area filter size 2.5 | Slightly blurs the image, visually more pleasing than the box filter. | ||
Catmull-Rom | Edge-enhancing filter, often used for architectural visualizations. Note that edge enhancing can produce "moire" effects on detailed geometry. | ||
Cook Variable size 2.5 | |||
Gaussian | Gaussian blur. |
Example: Anti-aliasing Filters and Moire Effects
This example demonstrates the effect anti-aliasing filters have on moire effects in your images. Sharpening filters may enhance moire effects, even if your image sampling rate is very high. Blurring filters reduce moire effects.
Note that moire effects are not necessarily a result of poor image sampling. In general, moire effects appear simply because the image is discretized into square pixels. As such, they are inherent to digital images. The effect can be reduced through the usage of different anti-aliasing filters, but is not completely avoidable.
The scene is very simple: a sphere with a very fine checker map applied. The images were rendered with a very high sampling rate (15 subdivs, or 225 rays/pixel). This is enough to produce quite an accurate approximation to the pixel values. Note that the image looks quite different depending on the filter:
No Filter
Box Filter
Area Filter, size = 1.5
Area Filter, size = 4.0
Triangle Filter, size = 1.5
Lanczos Filter
Catmull Rom
Gaussian Filter, size 1.5
Gaussian filter, size = 6.0
Example: Render Mask
The original image
The same image, only objects with chrome material were re-rendered
The actual render mask image - RGB channels
The actual render mask image - Alpha channel
Progressive Sampler
This section provides information specific to the Progressive Sampler Type. The Progressive sampler renders the entire image progressively in passes.
The advantage of this sampler is that you can see an image very quickly, and then let it refine for as long as necessary as additional passes are being computed. This is contrast to the bucket-based image samplers, where the image is not complete until the final bucket is done.
A disadvantage is that more data needs to be kept in memory, especially when working with render elements. Also, when using distributed rendering, because of the continuous refinement, frequent communication between the client machine and the render servers is required, which may reduce the CPU utilization on the render slaves. This effect can be controlled to some extent using the Ray bundle size parameter.
Min Subdivs – Controls the minimum number of samples that each pixel in the image will receive. The actual number of the samples is the square of the subdivs. Note: Not available when using a GPU-based Production engine.
Max Subdivs – Controls the maximum number of samples that each pixel in the image will receive. The actual number of the samples is the square of the subdivs. If zero, the number of samples is not limited.
Noise Threshold – The desired noise level in the image. If this is 0.0, the entire image is sampled uniformly until either the Max. subdivs value is reached or the Render time limit is reached.
Max. Render Time (min) – The maximum render time in minutes. This is the render time for the final pixels only; it does not include any GI prepasses like light cache, irradiance map etc. If this is 0.0, the render is not limited in time.
Ray Bundle Size – Useful for distributed rendering to control the size of the chunk of work that is handed to each machine. When using distributed rendering, higher values may help to utilize CPUs on the render servers better.
Avoid using the Progressive sampler with sharpening image filters (Catmull-Rom, Mitchell-Netravali) as this may slow down the rendering - additional image samples will be required to resolve sharpening filters properly. V-Ray will print a warning in this case in the V-Ray messages window.
Example: Stages of Rendering with the Progressive Sampler
Image after 1 pass
Image after 16 passes
Image after 64 passes
Image after 256 passe
Adaptive Sampler
This section covers information specific to the Bucket Sampler Type.
This sampler makes a variable number of samples per pixel based on the difference in intensity between the pixel and its neighbors.
This is the preferred sampler for images with lots of small details (like Procedural Fur for example) and/or blurry effects (DOF, motion blur, glossy reflections etc).
The diagram above shows visually the way V-Ray is placing samples when using the Bucket sampler. The black squares represent the pixels of the image while the dots represent the individual samples. In the first pass V-Ray always places the minimum number of samples determined by the Min. subdivs parameter. Then the color of the samples is compared and more are added where needed in the following passes.
Lock Subdivs – Sets a fixed number of samples taken for each pixel.
Min Subdivs – Determines the initial (minimum) number of samples taken for each pixel. You will rarely need to set this to more than 1, except if you have very thin lines that are not captured correctly, or fast moving objects if you use motion blur. The actual number of samples is the square of this number (e.g. 4 subdivs produce 16 samples per pixel).
Max Subdivs – Determines the maximum number of samples for a pixel. The actual maximum number of samples is the square of this number (e.g. 4 subdivs produces a maximum of 16 samples). Note that V-Ray may take less than the maximum number of samples, if the difference in intensity of the neighboring pixels is small enough.
Threshold – The threshold that will be used to determine if a pixel needs more samples. For more information, see The Threshold Parameter example below.
Example: The Threshold Parameter
This example deals with texture anti-aliasing and the effect of the color threshold for the Bucket sampler.
By default V-Ray anti-aliases everything in the image, including textures. This is especially useful for textures with small details or noisy bump maps. The Threshold parameter controls the extent to which texture anti-aliasing is performed. The effect of this parameter is most noticeable with low min rates. For the four images below, min/max rate of -3/2 was used:
Threshold 10.0
Threshold 5.0
Threshold 1.0
Threshold 0.1
Note that the edges of the object in those images are always sharp.
If you set the Threshold to a high value, you are effectively telling V-Ray not to anti-alias textures. You can use this fact to speed up the rendering of complex materials. Note however, that this will disable anti-aliasing of V-Ray shadows, reflections etc as well.
- A note on RAM usage: image samplers require substantial amount of RAM to store information about each bucket. Using large bucket sizes may take a lot of RAM.
