© Bertrand Benoit
« Previous Version 40 Next »
This page provides a table of currently supported features by V-Ray for Unreal.
These features are supported by V-Ray for Unreal. Currently supported versions of Unreal Engine are 4.19.2 and 4.20.3.
For best results when importing vrscene files make sure your scenes are authored and optimized for V-Ray GPU Next or V-Ray GPU 3.6.
All supported features from Unreal Engine are exported in the .vrscene. See Exporting vrscene files table below for full list.
Only Render nodes for V-Ray Next are supported.
V-Ray for Unreal only supports normal maps in tangent space.
V-Ray for Unreal uses only the V-Ray Hybrid engine.
Supported Features
VRScene and Rendering
Importing vrscene files
Cameras
3ds Max Physical Camera:
  • Film/Sensor - Preset; Width
  • Lens - Focal Length; Specify FOV; Aperture;; Custom Focus Distance
  • Shutter - Type 1/seconds; Duration
  • Exposure Gain - Manual
  • White Balance Custom
VRay Physical Camera
  • Focus Distance; Target Distance; Field of view; Film gate; Focal length; Film Speed (ISO); F-number; Shutter speed(s^-1); Exposure; Custom White balance
Geometry
  • Triangle meshes
  • VRayProxy - initial support, no animated meshes
  • UV channels 0, 1, 2, 3
Lights
3ds Max
  • Standard
    • Spotlight - Light - On/Off; Shadows - On/Off; Multiplier; Decay type - None, Inverse Square; Hotspot; Falloff
    • Omni - Light - On/Off; Shadows - On/Off; Multiplier; Decay type - None, Inverse Square
    • Direct - Light - On/Off; Shadows - On/Off; Multiplier
  • Photometric
    • Photometric web - Light - On/Off; Shadows - On/Off; Photometric Web profile; Filter Color; Intensity in lumens
  • V-Ray
    • Dome light - Light - On/Off; Units - Default image; Multiplier; Color; Texture
    • Sphere light - Light - On/Off; Color; Units - Luminous power; Multiplier; Cast Shadows - On/Off
    • Rectangle light - Enabled - On/Off; Light color; Intensity multiplier; Units - Lumens; Shadows - On/Off
    • IES light - Enabled - On/Off; IES file; Cast shadows - On/Off; Color; Intensity type - lumens
    • Sun - Enabled - On/Off; Turbidity; Sky model - Hosek et al.
Maya
  • V-Ray
    • Dome light - Enabled - On/Off; Light color; Intensity multiplier; Dome Tex
    • Sphere light - Enabled - On/Off; Light color; Intensity multiplier; Units - Lumens; Shadows - On/Off
    • IES light - Enabled - On/Off; IES File Name; Light color; Intensity; Shadows - On/Off
    • Sun - Enabled - On/Off; Turbidity; Sky Model - Hosek et al.
Materials
  • VRayMtl
  • VRay2SidedMtl
  • VRayBumpMtl
  • VRayLightMtl
Textures
3ds Max
  • Bitmap
  • VRayHDRI
  • VRayNormalMap
Maya
  • File
  • Gamma
Textures with file format:
  • .tga
  • .hdr
Other
  • 3ds Max Exposure Control
  • VRay Exposure Control
Cameras
Unreal
  • Camera Actor - Transformations
  • Cine Camera Actor - Transformations
VRay
  • VRayPhysicalCamera BP
    • Current Camera Settings - Sensor Width, Sensor Height; Focus Method; Manual Focus Distance; Current Focal Length
    • V-Ray Physical Camera Settings - 3ds max Compatible; Enable Exposure; Film Speed(ISO); Shutter Speed S^-1; F-number; White Balance
    •  Color Mapping - Reinhard Burn Value
Geometry
  • Static Meshes
  • Blueprint Actors with Static Meshes
  • Foliage
Lights
Unreal
  • Point Light - Intensity; Light Color; Intensity Units; Source Radius; Affects World; Cast Shadows; Use Inverse Squared Falloff
  • Spot Light - Intensity; Light Color; Intensity Units; Inner Cone Angle; Outer Cone Angle; Source Radius, Affects World; Cast Shadows; Use Inverse Squared Falloff; IES Texture
  • Directional Light - Intensity; Light Color; Affects World; Cast Shadows; Light Source Angle
V-Ray
  • VRaySunAndSky BP - Auto Update; Elevation; Azimuth; On; Turbidity
  • VRayLightDome BP - On; Use Dome Tex; Dome Tex; Dome Tex Rotation; Dome Color; Intensity; Auto Update
  • VRayLightRect BP - Enable, Is Disc, Length/Radius, Width, Multiplier, Cast Shadows, Color, Invisible
Materials
Unreal Materials supported expressions:
  • Constant
    • Constant
    • Constant2Vector
    • Constant3Vector
    • Constant4vector
  • Coordinates
    • TextureCoordinate
  • Functions
    • FunctionInput
    • FunctionOutput
    • StaticBool
    • StaticSwitch
  • Math
    • Abs
    • Add
    • AppendVector
    • Clamp
    • ComponentMask
    • Cosine
    • CrossProduct
    • Divide
    • DotProduct
    • LinearInterpolate
    • Max
    • Multiply
    • OneMinus
    • Power
    • Saturate
    • Sine
    • SquareRoot
    • Subtract
  • Parameters
    • ScalarParameter
    • StaticBoolParameter
    • StaticSwitchParameter
    • VectorParameter
    • TextureObjectParameter
    • TextureSample2DParameter
  • Texture
    • TextureObject
    • TextureSample
  • Utilities
    • Fresnel
  • VectorOps
    • CameraVectorWS
    • PixelNormalWS
Unreal Materials supported Inputs:
  • Base Color
  • Metallic
  • Specular
  • Roughness
  • Emissive Color
  • Opacity
  • Normal
Unreal Materials supported Blend Modes:
  • Opaque
  • Translucent
Unreal Materials supported Shading Modes:
  • Default Lit
Material Instances, V-Ray Material Instances with V-Ray Parent Materials:
  • VRayMtl
  • VRayCarpaintUberMtl
  • VRayPBRMtl
Textures
Texture with Compression Settings:
  • Default
  • Normalmap
  • Grayscale
  • HDR
  • .tga
  • .hdr
Render Elements
  • Denoiser (NVidia Ai, V-Ray)
  • Background, GI, Lighting, Reflection, Refraction, Specular, Self Illumination, Sub Surface Scattering 1
  • Diffuse Filter, Reflection Filter, Refraction Filter, Shadows
  • RenderID
  • Normals, Bump Normals, Sampler Info, Velocity, ZDepth
  • Light Select
  • Sample Rate, Unclamped Color, Noise Level
Other
  • Sequencer animation with Static Meshes
Unreal
  • Project packaging/cooking into a standalone application
  • Light bake with V-Ray Bake
Footnotes
1 – Only for materials that have "Render materials from .vrscene" option enabled
