This page gives some basic details about the Refraction Raw Render Element and how it is used in compositing.
Page Contents
The Refraction Raw Render Element is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials will contain no information in the render element and therefore will render as black.
In comparison, the Refraction Filter Render Element is a render element that indicates varying degrees of refraction in the scene through brightness values in the image. Multiplying these two render elements together produces the Refraction Render Element.
To properly calculate the Refraction Raw Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
UI Path: ||Toolbar|| > V-Ray Menu icon > Render > VRayRenderElement > Type: Refraction Raw
Properties
The Refraction Raw render element has no controllable properties.
Common Uses
The Raw Refraction Render Element is useful for changing the appearance of refractive elements after rendering in a compositing or image editing application. Below are examples of possible uses.
Original Beauty Composite
Raw Refraction Render Element with added contrast
Tinted Raw Refraction Render Element with added contrast
Refractions with more contrast
Tinted Refractions with more contrast
Underlying Compositing Equation
Refraction Raw x Refraction Filter = Refraction
- To properly calculate the refraction information in the Refraction Raw and Refraction Filter Render Elements, the Refraction Render Element must also be rendered at the same time, even if it's not going to be used in the compositing process. Doing so enables all the refraction information to be included in the rendering calculations.
