© Bertrand Benoit
« Previous Version 15 Next »
This page provides information on the native Unreal Materials and Material Instances.
V-Ray for Unreal support the rendering of native Unreal Materials and Material Instances. Materials are used to calculate how light interacts with surfaces. These calculations are done using incoming data that is input to the Material from a variety of images (textures) and math expressions, as well as from various property settings inherent to the Material itself. Each time a change is made in the material it has to recompile which can be very time consuming depending on the complexity of the shading graph. Material instancing is used to change the appearance of a Material without incurring an expensive recompilation of the Material using predefined parameters. For more information on Unreal Materials and Material Instances check the Materials documentation.
Supported Expressions
Below are listed the expressions in the Material Editor that are supported by V-Ray for Unreal.
Native Unreal Materials are supported in Hybrid rendering. Make sure you meet the System Requirements.
CategoryExpressions
Atmosphere
 Support
AtmosphericFogColorNOT SUPPORTED
Constants
 Support
ConstantSUPPORTED
Constant2VectorSUPPORTED
Constant3VectorSUPPORTED
Constant4VectorSUPPORTED
DistanceCullFadeNOT SUPPORTED
ParticleColorNOT SUPPORTED
ParticleDirectionNOT SUPPORTED
ParticleMotionBlurFadeNOT SUPPORTED
ParticleRadiusNOT SUPPORTED
ParticleRelativeTimeNOT SUPPORTED
ParticleSizeNOT SUPPORTED
ParticleSpeedNOT SUPPORTED
PerInstanceFadeAmountNOT SUPPORTED
PerInstanceRandomNOT SUPPORTED
Time 2PARTIAL
TwoSidedSignSUPPORTED
VertexColorSUPPORTED
View Property 1PARTIAL
Precomputed AO MaskNOT SUPPORTED
Coordinates
 Support
LightmapUVsNOT SUPPORTED
 ObjectRadiusSUPPORTED
PannerSUPPORTED
ParticlePositionWSNOT SUPPORTED
RotatorSUPPORTED
SceneTexelSizeNOT SUPPORTED
ScreenPositionSUPPORTED
TextureCoordinate 3PARTIAL
ViewSizeNOT SUPPORTED
WorldPosition SUPPORTED
Custom
 Support
CustomNOT SUPPORTED
Depth
 Support
DepthFadeNOT SUPPORTED
 PixelDepthSUPPORTED
SceneDepthNOT SUPPORTED
Function
 Support
FunctionInputSUPPORTED
FunctionOutputSUPPORTED
MaterialFunctionCallSUPPORTED
StaticBoolSUPPORTED
StaticSwitchSUPPORTED
Material Attributes
 Support
BreakMaterialAttributesSUPPORTED
(plus) NEW GetMaterialAttributesSUPPORTED
MakeMaterialAttributesSUPPORTED
(plus) NEW SetMaterialAttributesSUPPORTED
Math
 Support
AbsSUPPORTED
AddSUPPORTED
AppendVectorSUPPORTED
 ArccosineSUPPORTED
ArccosineFastPARTIAL
 ArcsineSUPPORTED
ArcsineFastPARTIAL
 ArctangentSUPPORTED
 Arctangent2SUPPORTED
Arctangent2fastPARTIAL
ArctangentFastPARTIAL
CeilSUPPORTED
ClampSUPPORTED
ComponentMaskSUPPORTED
CosineSUPPORTED
CrossProductSUPPORTED
DivideSUPPORTED
DotProductSUPPORTED
FloorSUPPORTED
FmodSUPPORTED
FracSUPPORTED
IfSUPPORTED
LinearInterpolateSUPPORTED
Logarithm10NOT SUPPORTED
 Logarithm2SUPPORTED
MaxSUPPORTED
MinSUPPORTED
MultiplySUPPORTED
NormalizeSUPPORTED
OneMinusSUPPORTED
PowerSUPPORTED
RoundSUPPORTED
SaturateSUPPORTED
SignSUPPORTED
SineSUPPORTED
SquareRootSUPPORTED
SubtractSUPPORTED
 TangentSUPPORTED
TruncateSUPPORTED
 Support
CollectionParametersNOT SUPPORTED
DynamicParameterNOT SUPPORTED
FontSampleParameterNOT SUPPORTED
ScalarParameterSUPPORTED
StaticBoolParameterSUPPORTED
StaticSwitchParameterSUPPORTED
StaticComponentMaskParameterNOT SUPPORTED
VectorParameterSUPPORTED
TextureObjectParameterSUPPORTED
TextureSampleParameter2DSUPPORTED
TextureSampleParameterSubUVNOT SUPPORTED
TextureSampleParameterCubeNOT SUPPORTED
TextureSampleParameterMovieNOT SUPPORTED
Particles
 Support
ParticleMacroUVNOT SUPPORTED
SphericalParticleOpacityNOT SUPPORTED
ParticleSubUVNOT SUPPORTED
Terrain
 Support
LanscapeLayerBlendNOT SUPPORTED
LandscapeLayerCoordsNOT SUPPORTED
LandscapeLayerSwitchNOT SUPPORTED
LandscapeLayerWeightNOT SUPPORTED
LanscapeVisibilityMaskNOT SUPPORTED
Texture
 Support
FontSampleNOT SUPPORTED
SceneColorNOT SUPPORTED
SpriteTrextureSamplerNOT SUPPORTED
TextureObjectSUPPORTED
TextureSampleSUPPORTED
TexturePropertyNOT SUPPORTED
Utility
 Support
AntialiasedTextureMaskNOT SUPPORTED
BlackBodyNOT SUPPORTED
BumpOffsetSUPPORTED
ConstantBiasScaleSUPPORTED
DDX 4PARTIAL
DDY 4PARTIAL
DepthOfFieldFunctionNOT SUPPORTED
DesaturationSUPPORTED
DistanceSUPPORTED
DistanceFieldGradientNOT SUPPORTED
DistanceToNearestSurfaceNOT SUPPORTED
FeatureLevelSwitchNOT SUPPORTED
FresnelSUPPORTED
GIReplaceNOT SUPPORTED
LightmassReplaceNOT SUPPORTED
NoiseNOT SUPPORTED
PreviousFrameSwitchNOT SUPPORTED
QualitySwitchNOT SUPPORTED
RotateAboutAxisSUPPORTED
SphereMaskSUPPORTED
Vector NoiseNOT SUPPORTED
VectorOps
 Support
ActorPositionWSNOT SUPPORTED
CameraPositionWSSUPPORTED
CameraVectorWSSUPPORTED
DeriveNormalZNOT SUPPORTED
LightVectorNOT SUPPORTED
ObjectBoundsNOT SUPPORTED
ObjectOrientationNOT SUPPORTED
ObjectPositionWSSUPPORTED
PixelNormalWSSUPPORTED
Pre-Skinned Local NormalNOT SUPPORTED
Pre-Skinned Local PositionNOT SUPPORTED
ReflectionVectorWSSUPPORTED
TransformSUPPORTED
TransformPositionPARTIAL
VertexNormalWSSUPPORTED
If the Coordinate Index in the TextureCoordinate node in a material is set to a certain value and the material is applied to a Static mesh that doesn't have a corresponding UV channel, then that mesh will not render correctly in V-Ray. For example, the Coordinate Index in a material that is applied to a static mesh is set to 3 but the mesh has only 2 UV channels then the render result will be inaccurate.
Supported Material Inputs, Blend Modes and Shading Models
Below are listed all inputs, Blend modes and Shading models in the Material Editor that are supported by V-Ray for Unreal.
Inputs
Base Color
SUPPORTED
Metallic
SUPPORTED
Specular
SUPPORTED
Roughness
SUPPORTED
Emissive Color
SUPPORTED
Opacity
SUPPORTED
Opacity Mask
SUPPORTED
Normal
SUPPORTED
World Position Offset
NOT SUPPORTED
World Displacement
NOT SUPPORTED
Tessellation Multiplier
NOT SUPPORTED
Subsurface Color
SUPPORTED
Clear Coat
SUPPORTED
Clear Coat Roughness
SUPPORTED
Ambient Occlusion
NOT SUPPORTED
Refraction
NOT SUPPORTED
Pixel Depth Offset
NOT SUPPORTED
Shading Model
NOT SUPPORTED
ClearCoatBottomNormal
SUPPORTED
Blend Modes
Opaque
SUPPORTED
Masked
SUPPORTED
Translucent
SUPPORTED
Additive
NOT SUPPORTED
Modulate
NOT SUPPORTED
Alpha Composite
SUPPORTED
Shading Modes
Unlit
SUPPORTED
Default Lit
SUPPORTED
Subsurface
SUPPORTED
Preintegrated Skin
NOT SUPPORTED
Clear Coat
SUPPORTED
Subsurface Profile
NOT SUPPORTED
Two Sided Foliage
SUPPORTED
Hair
NOT SUPPORTED
Cloth
NOT SUPPORTED
Eye
NOT SUPPORTED
Footnotes
1 – Only Camera Position (Absolute World Space) and Viewport Offset are supported.
2 – Time is not currently supported in animation.
3 – Tiling and mirror options are not supported.
4 – Will be skipped in the shader graph.
