This page provides information on installing V-Ray for 3ds Max.
This guide is to serve as a reference for installing V-Ray for 3ds Max and 3ds Max Design.
You can download the latest official version of V-Ray from http://www.chaosgroup.com with the account supplied to you by Chaos Group or your reseller.
If you experience any problems, please check the Installation FAQ.
A complete installation of V-Ray for 3ds Max consists of:
V-Ray
V-Ray GPU
V-Ray Standalone
V-Ray DR Spawner
V-Ray license server
V-Ray tools
V-Ray SDK
- V-Ray Chaos Cloud Client
Installing V-Ray for 3ds Max
The V-Ray installer will automatically remove any previous installations. This will allow you to seamlessly upgrade from previous versions. If you experience problems you can manually uninstall the previous versions to perform a clean install. For more information please refer to the Uninstall V-Ray page.
Before running the installation, make sure your Windows account has administrative privileges.
Run the installer.
1. Upon the start of the installation, Windows may ask you for permission to run the installer with administrator privileges. Please confirm.
2. You will be presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Check the I accept the Agreement checkbox and click Install to proceed with standard installation.
If you need to customize your V-Ray installation, press the Advanced button.
After you click the Install button, the installer will proceed to uninstall any previous versions and install V-Ray Next on your machine.
If the installer detects any applications that need to be closed, they will be listed before being able to continue. Please close them and click Continue.
3. Now V-Ray 5 is ready to render!
To make sure that your license server is up and running and you have the necessary licenses, please proceed to the Set Up Your V-Ray License page.
The License Server will skip its installation process for two reasons:
- If it detects a previous installation of the Online License Server on your machine.
- If you choose the option Remote V-Ray license server on the network.
When installing the License Server, you are directed to the License Server local host (http://localhost:3004) in order to sign in and activate it.
