©BBB3viz
Version 1 Next »
This page gives information about the Sampler Info Render Element.
The Sampler Info Render Element is a color image that provides information about the scene, with the choice to show any of various aspects as color blocks. This render element provides information about various aspects of the shaded points such as position, normal, bump normal, reflection/refraction vectors and UVW coordinates. This render element can be used either for world position passes or normal passes. It extracts particular information about the scene, converting the gathered information into RGB data for use in compositing.
UI Path:
||Render Setup window||  > Render Elements  tab  > Add  button  > VRaySamplerInfo
vrayVFB – Enables the render element inside the V-Ray frame buffer.
deep output – Specifies whether to include this render element in deep images.
type  Controls the type of render element produced by VRaySamplerInfo:
Point  The X, Y, and Z coordinates of the point are converted to RGB data according to the coord system that is set. This outputs a Position Pass for use in compositing.
Normal vector  The direction of the normal at the particular shaded point according to which coord system is set.
Reflection vector  Commonly used for adjusting reflections in the composite.
Refraction vector – Commonly used for adjusting refractions in the composite.
UVW coordinates – Extracts the UVW coordinates of the object at the particular shaded point.  This can be used to apply another texture at a composite level.
Normal vector with bump mapping –  Produces the bump normal according to the coord system that is set.
Backward occlusion  The red and green components of this render element represent the screen position of the shaded point at the beginning of the motion-blurred frame, while the blue component represents camera occlusion at the beginning of the motion-blurred frame. Together with the Forward occlusion render element, this can be used for denoising and/or post-process motion blur.
Forward occlusion  The red and green components of this render element represent the screen position of the shaded point at the end of the motion-blurred frame, while the blue component represents camera occlusion at the end of the motion-blurred frame. Together with the Backward occlusion render element, this can be used for denoising and/or post-process motion blur.
Integer ID from node user attribute  Extracts any integer node user property into an integer render element. Can be used as an extended Object ID.
Float number from node user attribute – Extracts any floating-point node user property into a single-channel floating-point render element. Can be used to extract additional masks.
Tangent vector in object space –  Displays tangent vector according to the Object space.
Bitangent vector in object space – Displays bitangent vector according to the Object space.
point multiplier Acts as a multiplier when type is set to Point.
refract ior  Sets the index of refraction when Refraction vector is set as the type.
uvw channel The UVW mapping channel used when the type is set to UVW coordinates.
uvw mode Specifies what happens to UVW values outside the 0.0-1.0 range of the unit texture square:
Normal Stores the UVW coordinates without modification.
Clamp UVW coordinates above 1.0 are clamped to 1.0, and values below 0.0 are clamped to 0.0.
Tile  Wraps the UVW coordinates to the unit texture square.
  coord system Controls the coordinate system used:
World – X, Y, and Z coordinates (in world space) of the point are converted to RGB data.
Object  X, Y, and Z coordinates (in object space) of the point are converted to RGB data.
Camera X, Y, and Z coordinates (in camera space) of the point are converted to RGB data.
relative X, Y, and Z coordinates in the object space of the relative node are converted to RGB data.
relative node  When coord system is set to relative, this specifies the scene node relative to which the point/vector data is stored.
output  Controls the way data is stored in the render element when the type is a normal vector, or a reflection/refraction direction:
Vector (signed)  Values are stored directly without modification, including negative components.
Color (unsigned)  Values are scaled down by 0.5 and offset by 0.5 so that (0, 0, 0) maps to (0.5, 0.5, 0.5), (-1, -1, -1) maps to (0, 0, 0) and (1,1,1) maps to (1,1,1). This avoids negative values which might be necessary for some compositing packages.
user attribute  Determines which user attribute to connect to when Integer ID from node user attribute or Float number from node user attribute are selected as type.
occlusion bias Controls the positional bias of the Backward occlusion Forward occlusion types in order to prevent incorrect self-occlusion.
Common Uses
The VRaySamplerInfoTex texture extracts particular information about the scene. It then converts the gathered information into RGB data that can be used for compositing.
with type set to Point (world space)
with type set to Normal vector
with type set to Reflection vector (world space)
with type set to Refraction vector (world space)
with type set to UVW coordinates
Sampler Info Render Element with type set to
The following examples have the coordinate system set to object space.
with type set to Point (object space)
Reflection vector (object space)
Refraction vector (object space)
The following examples have the coordinates system set to camera space.
Sampler Info Render Element with type set to Point (camera space)
Sampler Info Render Element with type set to Reflection vector (camera space)
Sampler Info Render Element with type set to Refraction vector (camera space)
Sampler Info Render Element with type set to Refraction vector (relative space)
The following examples have the coordinates system set to relative space.
Sampler Info Render Element with type set to Point (relative space)
Sampler Info Render Element with type set to Reflection vector (relative space)
Example: Re-texturing in composite
Using the VRaySamplerInfo Render Element it is possible to apply a new texture to an already rendered still or sequence via setting its type to UVW coordinates. This then enables the creation of what effectively amounts to a new Diffuse Filter Render Element which can then be used in a composite, enabling a change of texture to be easily made. It is worth noting that any UV stretching on the model will carry through into the UVW pass created by VRaySamplerInfo as can be seen in the examples below.
The Sampler Info with type set to UVW coordinates (uvw mode = normal)
Beauty render prior to re-texturing in composite
New texture image applied in composite.
(This effectively creates a new Diffuse Filter Pass)
Re-textured Beauty render (done purely at a composite level)
Supported UVW Coordinate Types
The table below provides some details on the supported UVW coordinate types within the Sampler Info Render Element. Pass types such as Normal, Normal vector with bump mapping, World coordinates and Point can be used to relight a scene at a composite level. While UVW coordinates and Object coordinates can be used to re-texture items in a scene in composite. The Reflection vector type can be used to adjust or remap reflections, similarly the Refraction vector can do the same at a composite level for refractions. Some types such as the Forward occlusion and Backwards occlusion can be used together for denoising and/or post-process motion blur while the Shading incidence type can be used as a mask in composite.
The Integer ID from node user attribute can be used as  an extended Object ID and the Float number from node user attribute can used to extract additional masks.
Pass TypeCoord. SystemUVW ModeOutputV-Ray RenderV-Ray GPU
PointWorld
PointObject
PointCamera
PointRelative
NormalWorld Vector (signed) or Color (unsigned)PARTIAL
NormalObject Vector (signed) or Color (unsigned)
NormalCamera Vector (signed) or Color (unsigned)PARTIAL
NormalRelative Vector (signed) or Color (unsigned)PARTIAL
ReflectionWorld Vector (signed) or Color (unsigned)
ReflectionObject Vector (signed) or Color (unsigned)
ReflectionCamera Vector (signed) or Color (unsigned)
ReflectionRelative Vector (signed) or Color (unsigned)
RefractionWorld Vector (signed) or Color (unsigned)
RefractionObject Vector (signed) or Color (unsigned)
RefractionCamera Vector (signed) or Color (unsigned)
RefractionRelative Vector (signed) or Color (unsigned)
UVW coordinates Normal
UVW coordinates Clamp
UVW coordinates Tile
Normal vector with bump mappingWorld Vector (signed) or Color (unsigned)
Normal vector with bump mappingObject Vector (signed) or Color (unsigned)
Normal vector with bump mappingCamera Vector (signed) or Color (unsigned)
Normal vector with bump mappingRelative Vector (signed) or Color (unsigned)
Backwards occlusion
Forward occlusion
