©BBB3viz
« Previous Version 3 Next »
This page gives an overview of the Reflection Filter Render Element and explains how it is used.
The Reflection Filter Render Element stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in its material(s) will contain no information in the render pass and will therefore render as black.
While the VRayRawReflection Render Element gives the full reflection of objects reflecting in the scene, VRayReflectionFilter shows how much of that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw image defines what is being reflected in the image. When these two elements are multiplied, the true level of reflection is given and produce VRayReflection. Using these component parts of the reflection, you can better fine tune the reflection in your final composite.
The Reflection Filter element is a sub-component in the main Beauty Pass.
UI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||  > Render Elements  tab  > Add  button  > VRayReflectionFilter
VrayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
Common Uses
The Reflection Render Element is useful for changing the appearance of Reflective elements after rending in a compositing or image editing software. Below are a couple of examples of their use.
The Original Beauty Composite
Increased Contrast of Reflection Filter
More reflective objects have increased reflections
Less reflective objects have less reflections
Colorized Reflection Filter
More reflective objects tinted orange
Less reflective objects tinted green
Underlying Composite
The Reflect render element is a product of  VRayRawReflection x VrayReflectionFilter.
