This page introduces the Volumetric Grid Parameters located in the Modify panel.
After the VRayVolumeGrid is created, its parameters can be accessed on the Modify panel.
UI Path
||Select V-Ray Volume Grid|| > Modify panel
Rollouts
The following rollouts contain parameters for modifying the volume grid.
- Frame Info Rollout - Displays information on the loaded volume data.
- Input Rollout - Provides controls for multiple frame input, timing of frames, and blending/smoothing of frames.
- Preview Rollout - Provides controls for how the volume grid effect is displayed in the viewport.
- Rendering Rollout - Provides controls for how the volume grid effect is rendered.
