© Taichi Kobayashi
« Previous Version 6 Next »
This page gives some basic details about the Reflection Glossiness render element and how it is used in compositing.
The Glossiness Render Element stores the image's reflection glossiness as a grayscale image that represents the degree of Reflection Glossiness set for materials in the scene. White areas have the most reflection glossiness, while dark areas have little.
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Reflection Glossiness
||mat Network|| > V-Ray > Render Channel > Reflection Glossiness
Attributes
Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.Glossiness.vrimg).
Filtering – Applies the image filter to this channel. Image filter settings are in the AA sub-tab of the Sampler tab of the  V-Ray Renderer node.
Deep Output – Specifies whether to include this render element in deep images.
