©BBB3viz
« Previous Version 2 Next »
This page provides information about the VRayCoronaScatterMod modifier in V-Ray for 3ds Max.
When using CoronaScatter object in 3ds Max, you can set up the rendering of the instances by using the VRayCoronaScatterMod modifier.
Note that by default, V-Ray renders CoronaScatter directly. The VRayCoronaScatterMod modifier introduces fine-tuning of the instances.
UI Path
||Modify panel|| (with CoronaScatter selected) > Modifier ListVRayCoronaScatterMod
random seed – This parameter allows the user to change the seed used for the random distribution.
render percent – Allows rendering of only a portion of the instanced geometry. The number of rendered instances is determined as a percentage of the total instances.
multithreaded – An experimental option to use multithreaded generation of the instanced meshes.
override node properties – Enabling this option allows global override of the object properties of the instances by the properties specified in VRayCoronaScatterMod.
