« Previous Version 11 Next »
Project Lavina Beta, v0.3.0
Beta Release
Date - June 26, 2020
New Features
  • Added Animation Editor (experimental)
  • Added Light grouping(instancing) on imported lights
  • Added support for V-Ray Sun and Sky models
  • Added Noise threshold option
  • Added Support for Simple(environment) light portal
  • Added support for CommonTexture and MappedTexture set of texture parameters: Crop, Place, AlphaSource, MonoChannelOutput, RGBChannelOutput, Invert, OutputAmount, Clamp, RGBOffset, RGBLevel
Modified Features
  • Improved Color Picker - interactive updates, color temperature, color presets, color range options
  • Improved UI:
    • Last snapshot render time information
    • Selecting a light focuses it in the light lister
  • Improved visual parity between Lavina and V-Ray
Project Lavina Beta, v0.2.3
Beta Release
Date - May 07, 2020
New Features
  • Added new Camera list with thumbnails and set, delete and reorder functionality
  • Added support for Directional, Omni and Spot lights from 3Ds Max
  • Added support for Instanced objects from Maya/Modo/Houdini
  • Added "Display to render ratio" control in the toolbar
Modified Features
  • Improved navigation - Selection Pivot Type
  • Improved denoiser - Artifacts with motion blur with fast moving objects are reduced
  • Improved denoiser - textures behind refractive objects are less blurry
  • Improved UI - RMB to reset value to default
Project Lavina Beta, v0.2.2
Beta Release
Date - April 09, 2020
New Features
  • Support for IES lights
  • Support for Spot lights from Maya/Modo/Katana/Cinema4D/Sketchup/Rhino
  • Object pivot import and manipulation
  • Move Pivot tool
  • Navigation target type option - Ray hit or Camera target
Modified Features
  • Improved navigation - gizmo for orbit pivot and zoom point
Bug Fixes
  • Fixed bug with rotation and scaling in local space
Project Lavina Beta, v0.2.1
Beta Release
Date - March 26, 2020
Modified Features
  • Improved denoiser blending - added simple adaptivity to raw/denoised blending to filter out extreme noise
  • Improved camera navigation
  • Improved camera transitions with quadratic interpolation function instead of linear
  • Improvement: Environment image is now cleared when loading a new scene
  • Improvement: Removed automatic cycle back to first camera when in "Camera" animation mode
  • Improved UI - removed Modifier key option and include them in navigation preset
  • Improved UI - Shortcuts update according to navigation preset
Project Lavina Beta, v0.2.0
Beta Release
Date - March 12, 2020
New Features
  • Support for opacity maps in "clip" mode. Only bitmaps are supported
  • Separate background option for camera rays instead of the "environment" color/image
  • Importing of Dome light texture as Environment
  • Navigation presets: Max, Maya, Sketchup
  • "Run" when in Free-Look mode
Modified Features
  • Improved rendering of refractive objects on reflective surfaces
  • Improved light cache - it is cleared when a render setting is changed
  • Improved animation experience: Scene, Walkthrough and Cameras mode
  • Improved scene navigation experience
  • Improved status bar
Bug Fixes
  • Fixed denoiser silhouette artifacts
  • Fixed collision enabled only in Free-Look mode
  • Fixed undo action for some local space rotations
