Square Enix © Goodbye Kansas
Version 1 Current »
Official Release
Date – Dec. 06, 2017
DownloadBuild 3.60.03
New Features
Cryptomatte
  • Support for refractive/reflective materials
  • Cryptomatte now works in DR without local host
  • Added Cryptomatte support in .vrimg and single channel EXR files
Viewport 2.0
  • Added support for color per vertex shaders with MASH
  • Added support for VRayFur UVs
V-Ray
  • Option to ignore all image planes
  • Option to disable DR in IPR
Modified Features
V-Ray
  • zDepth render element infinity color is now always black
  • Color corrections will not be applied to integer and filter render elements
  • Improved Hypershade Material Viewer responsiveness
  • Maximal mip-map resolution is now inclusive
XGen
  • XGen caches will now use a single file
Bug Fixes
V-Ray
  • Fixed crashes related to swatch rendering
  • Fixed wrong ZDepth on pixels bordering the environment
  • Fixed random crashes with swatches on materials with tiled textures
  • Fixed slow IPR update when moving sun position
  • Fixed error when opening or rendering scenes with camera projected textures
  • Fixed IPR not detecting changes to the shadow bias attribute on standard lights
VrayMtl
  • Fixed refraction with unclamped opacity
VRayRectLight
  • Fixed light getting cut off in VRayEnvironmentFog
VRmat
  • Fixed VRmat converter outputting invalid .vrmat files
XGen
  • Fixed path issues when changing XGen cache location
  • Fixed render density multiplier not working with XGen Interactive Groomable Splines
VRayDomeLight
  • Fixed slow swatch update
Viewport 2.0
  • Fixed wrong VRaySky preview in VP2
  • Fixed selection issue with VRayMesh in GPU preview mode
VRayFur
  • Fixed light linking with VRayFur from a referenced scene
VRayStereoscopic
  • Fixed a crash when changing global FOV camera override in IPR
