© Taichi Kobayashi
Version 1 Next »
This page provides information about the V-Ray Object Select Render Element in V-Ray for Houdini.
The Object Select Render Element stores only the object(s) called out with a specific Object or Material ID.
This effect is reversible to create a render element that excludes a particular object or objects according to Object or Material ID.
When rendering this element out, it will also include a filter and alpha passes separately to help make it easier to use when compositing.
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Object Select
||mat Network|| > V-Ray > Render Channel > V-Ray Object Select
Object/Material ID – List of selected IDs included in this render pass.
Use Material IDs – When enabled, the pass considers the Material ID and renders accordingly. When disabled, these values are considered to be the Object ID.
Invert Selection – Use the opposite of the selected objects in the render pass.
Affect Matte Objects – Specifies whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material.
Denoise –  Enables the render element's denoising, provided the Denoiser render element is present.
Deep Output – Specifies whether to include this render element in deep images.
Common Uses
The Object Select render element allows items to be isolated for easier control at a composite level. In the example shown below the robot arms at the front of the frame have been color corrected and tinted blue.
Object Select render Element
The original beauty Composite
Color Corrected and tinted Object Select Render Element
Robot arms tinted and color corrected via the Object Select Render Element
  • Object Select Render Element does not support Volumetric effects. For Volumetric effects supported render elements, visit the V-Ray Render Elements Support page.
