This page provides information on the Sheen Reflection Render Element.
The Sheen Reflection Render Element stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their materials will contain no information in the render pass and will therefore render as black.
The Sheen Reflection Render Element is formed by multiplying the Raw Sheen Reflection Render Element by the Sheen Filter Render Element . So while the raw sheen reflection pass gives the full reflection of objects reflecting in the scene, the sheen reflection filter sets how much of that reflection should come through in the composite. The two are multiplied together to create the Sheen Reflection pass which gives a true representation of the reflection in the scene.
UI Path: ||V-Ray|| > Render Elements > Sheen Reflection
Properties
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Aa – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
