This page describes how to set up your local system so that it loads the files for the correct version.
Installing V-Ray for Cinema 4D from a .zip file provides the advantage of easy setup and flexible folder management.
Required Steps
- Unpack the .zip file to a directory of your choice.
- Select the V-Ray folder and cut or copy it.
Paste it to the Maxon's plugins folder. By default, it is located in C:\Program Files\Maxon Cinema 4D Rxx\plugins.
If you already have an existing V-Ray folder there, replace it with the one from the archive.
- You are all set and ready to start Cinema 4D, where V-Ray is automatically loaded.
