« Previous Version 7 Next »
This page provides information on the minimum required hardware to run V-Ray.
 Please note that V-Ray for SketchUp version 2.0 and earlier are no longer supported.
Windows
Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64-bit operating systems and 64-bit versions of SketchUp.
Processor
1st Gen Intel® Core™ or compatible processor with SSE4.2 support (x64)
RAM
Minimum 8 GB RAM, recommended 16 GB RAM
TCP/IP
Only IPv4 is supported. IPv6 is currently not supported
Operating System
Windows® 8.1, Windows 10.
SketchUp
SketchUp 2016 (64-bit), 2017, 2018, 2019, 2020
GPU SupportMaxwell-, Pascal-, Volta- and Turing-based NVIDIA card(s) with latest video driver or at least version 411.31
For more info, see GPU Rendering.
Mac OS X
Processor
RAM
TCP/IP
Operating SystemApple® Mac OS X 10.10.x or higher
SketchUpSketchUp 2016 (64-bit), 2017, 2018, 2019 and 2020
 V-Ray GPU works only with C++/CPU devices under macOS. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s).
For more information on hardware, see the Hardware Recommendations article.
