« Previous Version 2 Next »
This page provides information on the V-Ray Color Texture.
The Color texture allows a flat color to be assigned as a texture.
Any texture can be replaced via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
Color
Color – Specifies a color to be used as a texture.
