« Previous Version 6 Next »
This page provides a step-by-step guide to creating a simple liquid simulation in Phoenix FD for 3ds Max.
This is an Entry Level tutorial which requires no previous knowledge of Phoenix FD. A basic understanding of 3ds Max would be helpful but is not a prerequisite for being able to follow along.
The instructions on this page guide you through the process of setting up a basic liquid simulation in Phoenix FD for 3ds Max. By the end of the tutorial, you will be able to create your own liquid simulations, understand how the simulation interacts with other objects and will know the basics of editing some of the main settings of the Phoenix FD Liquid Simulator.
To follow the described steps, you will need the Phoenix FD for 3ds Max plugin installed. If you notice a major difference between the results shown here and the behavior of your setup, please send an email to support@chaosgroup.com.
This tutorial is a companion to go along with the QuickStart video posted on our YouTube channel.
The Download button below provides you with an archive containing the start and end scenes.
Download Project Files
System Units Setup
Scale is crucial for the behavior of any simulation. The real-world size of the Simulator in units is important for the simulation dynamics. Large-scale simulations appear to move more slowly, while mid-to-small scale simulations have lots of vigorous movement. When you create your Simulator, you must check the Grid rollout where the real-world extents of the Simulator are shown. If the size of the Simulator in the scene cannot be changed, you can cheat the solver into working as if the scale is larger or smaller by changing the Scene Scale option in the Grid rollout.
The Phoenix FD solver is not affected by how you choose to view the Display Unit Scale - it is just a matter of convenience.
Go to Customize → Units Setup and set Display Unit Scale to Metric Centimeters.
Also, set the System Units such that 1 Unit equals 1 Centimeter.
The units do not have to be set to centimeters to get the simulation to work. What's important is that the emitter (in this case, the sphere) is set to the proper real-world scale so that the simulation is correct for that situation. This is how Phoenix FD is able to know if it's simulating water in a glass or a boat on ocean waves.
Lightning and Rendering
To prepare your scene for rendering a simulation make sure V-Ray is set as your Renderer in the Render Setup window.
Add a Dome Light to your scene and set it to be Invisible.
Scene Setup
In the following steps we will show how to create a basic liquid simulation with the Phoenix FD Tap Water Preset.
After that we will explain how to set the simulation manually step-by-step for greater flexibility and control.
Tap Water Preset
We will begin by using a quick water preset.
Create a Sphere with a Radius of about 4.0 centimeters. This sphere will be the source of the liquid.
With the sphere selected, click on the Tap Water Preset button from the Phoenix FD Toolbar
Now press the Start Simulation button in the toolbar.
Let the simulation run for a few seconds and you will have a chance to see the results in the viewport, click the Stop button to end the simulation process.
Render your current frame to see the simulation results.
Note that the liquid fills the simulation volume container as it flows.
Manual Water Setup
Let’s take a look at setting up a water simulation manually.
If you are continuing from the Preset section above, select the Liquid Simulator and Source objects and delete them from your scene. If not, create a Sphere with a Radius of about 4.0 centimeters.
Click on the Create a Liquid Simulator button in the Phoenix FD Toolbar and click and drag in the viewport to create a volume to encompass the sphere, while leaving some room for the liquid to fall. Move the sphere near the top of the Simulator and make sure it is inside the volume.
Click the Create a Liquid Source button on the Phoenix FD Toolbar and place the source in your scene.
The Source object is a 2D non-renderable icon, so size and placement are only important for being able to select the Source when needed.
With the Liquid Source object selected, go to the Modify Panel and click the Add button located under the Emitter Nodes list, then select the Sphere.
This way the sphere will be selected as an emitter.
The Source node is where we control the Emitter properties, like the Emit Mode ant the Outgoing Velocity. The sphere is the actual emitter of the fluid inside the Simulator.
Select the Simulator. In the Modify Panel under the Grid rollout are located the parameters to control the resolution of the volume grid, which greatly affects the look and performance of the simulation.
Click Decrease Resolution until the Total Cells value is around 3-4 million cells. You can also set the Cell Size to change the number of Total Cells.
Click the Start Simulation icon in the Phoenix FD Toolbar to confirm that the sphere is emitting the liquid inside the Simulator.
Now let’s get this simulation to look more like what we had with the preset.
Right now the edges of the pour are pretty jagged.
Expand the Dynamics rollout and adjust the Steps Per Frame to 12. This provides for a more natural look but will make the simulation run slower. The higher the Steps Per Frame, the longer the calculations, so try to find the lowest setting for the effect you need.
At this point the liquid is flowing right through the floor and disappearing. This means that the walls of the Simulator are open. Let's close them.
Open the Grid rollout, you can see the Container Walls are indeed all set to Open. Set the X/Y/Z values to Jammed Both
Start the simulation again. As the simulation runs, the liquid now looks smoother and collides with the bottom and the side walls of the Simulator.
It is, however, running slowly, so we can adjust the resolution by increasing the Cell Size or decreasing the Total Cells.
Stop the simulation and navigate to the Grid rollout. We currently have 3-4 million cells to calculate, so click Decrease Resolution until Total Cells amount is about half a million cells.
Start the simulation again and you’ll see it is running faster. While the simulation is still running, go to the Dynamics rollout and set the Steps Per Frame to 1 to speed it up some more.
Feel free to experiment with different settings.
It's time to create a water material and apply it to the Simulator.
Open the Material Editor and create a new V-Ray Material.
Set the Diffuse color to RGB [ 0, 0, 0 ].
Set the Reflect and Refract colors to RGB [ 255, 255, 255 ].
Set the Fresnel IOR to 1.33.
Assign the material to the Simulator and render a frame.
Feel free to adjust the material and the lighting in the scene to achieve the liquid look you’re going for.
Example Scene
Now let’s make the liquid collide with and fill an actual object rather than just the Simulator’s grid.
The following scene file can be downloaded from the Overview section above. It consists of a jar with a studio lighting setup and background.
Open the provided scene and switch the view to PhysCamera001 to see what will be rendered.
Return to the Perspective view and select the sphere. In the Phoenix FD Toolbar click the Tap Water Preset like we did before.
We will need to adjust the Simulator Grid Size so that it covers both the sphere and the jar. Again, use the X/Y/Z size parameters in the Grid rollout.
Use the Size attributes of the Simulator as opposed to simply scaling the Simulator container with 3ds Max's Scale tool, as that may adversely affect the simulation.
Start the simulation. Once it is finished, go back to the camera view. Here is how the simulation looks so far on frame 23.
Next, we will create materials for the water and the glass jar.
Assign this material to the Simulator.
Create another V-Ray Material for the glass jar.
Set the Fresnel IOR to 1.6.
Select the glass part of the jar and assign this material.
Render a frame to see how the fluid is interacting with the jar. Any geometry inside a simulation container will automatically interact with the emitting fluid. In addition, geometry can be excluded from interactions, and you can even create non-solid geometries, which are geometries that a simulation can flow through, but still be used as sources or forces acting on the simulation. You can find more about this topic in our Solid and Non-Solid Bodies QuickStart tutorial.
With the current simulation the fluid will eventually overflow the jar. To control how much fluid is discharged by the emitter, select the Liquid Source object and locate the Outgoing Velocity parameter. Animating this value will control how much liquid is created, which can be used to start and stop the pouring of water.
Before proceeding, let's lower the simulation resolution.
Select the Simulator and navigate to the Grid rollout. Click the Decrease Resolution button three times to lower the Total Cells to around 1.6 million cells.
We will animate the pour next, so scrub through the timeline to return to the start. Select the Liquid Source and set the Outgoing Velocity to 16.
Note that if this value is set to 0 on the first frame, nothing will be emitted even if you start the simulation.
Next, scrub ahead to frame 23 and click the Auto Key button.
Set the Outgoing Velocity to 0 at frame 23. With the current keys the Outgoing Velocity will gradually decrease from 16 to 0, which is not the effect we want.
Click and drag the key at frame 0 over to frame 20, so the liquid starts with a steady pour and then abruptly stops between frame 20 and 23.
Now that the pour animation is set, turn off Auto Key. Go back to the beginning and start the simulation.
After the simulation resolves you may notice that the result appears a little choppy if you scrub through the timeline. To fix this, select the Simulator, go to the Preview rollout and turn off Show Mesh. Only particles for the liquid pour will be displayed and the simulation will scrub faster. At any point in the simulation you can turn Show Mesh back on to see the liquid better.
Notice at around frame 30, at the top of the pour, there is a large spread of drops coming out of the emitter. This is because the emission is coming from the surface of the sphere.
To fix this, select the Liquid Source object and change the Emit Mode to Volume Brush. What this means is that instead of emitting the liquid from the surface area of the sphere, it will now emit from the whole volume of the sphere.
A window will ask to convert the emitter to a Non-Solid object. Select Yes. This will prevent the sphere geometry from interacting with the liquid simulation.
Finally, select the Simulator and under the Dynamics rollout reduce Steps Per Frame to 5.
Start the simulation. Notice that the spread out droplets are no longer an issue.
Return to the camera view and render a frame to see how the simulation looks.
