• Phoenix Simulator → Volumetric Heat Haze and Isosurface rendering is not supported yet with V-Ray GPU and V-Ray GPU IPR.
  • Phoenix Particle Shader → Cellular Render Mode is currently not supported with V-Ray GPU and V-Ray GPU IPR.
  • If you are using Phoenix 5.10 or later, you will need the latest V-Ray 6 Stable build to get correct results when rendering the Phoenix Particle Shader with V-Ray GPU.
List of the Supported V-Ray Features
Chaos Phoenix 5.24 Official
Release
V-Ray 6
CPU
V-Ray 6
GPU
V-Ray 6
CPU IPR
V-Ray 6
GPU IPR
V-Ray 7
CPU
V-Ray 7
GPU
V-Ray 7
CPU IPR
V-Ray 7
GPU IPR
Phoenix Simulator, Volumetric Render Mode**
Phoenix Simulator, Volumetric Geometry/Volumetric Heat Haze/Isosurface Render Mode
Volumetric Heat Haze and Isosurface are not supported.
Volumetric Heat Haze and Isosurface are not supported yet.
Phoenix Simulator, Mesh/Ocean Mesh/Cap Mesh Render Mode
Particle Shader
Cellular Mode is not supported.
Cellular Mode is not supported yet.
Particle Shader, Render as Geometry
* - Phoenix Simulator → Volumetric Render Mode is supported since Phoenix 5.01.00, Nightly Build: 31567, from 09 Aug 2022.
  • Phoenix Particle Shader → Points and Cellular Render Modes are not supported with V-Ray 5 GPU and V-Ray 5 GPU IPR.
  • If you are using Phoenix 5.10 or later, you will need the latest V-Ray 5 Stable build to get correct results when rendering the Phoenix Particle Shader with V-Ray GPU.
Release
V-Ray 5, update 2.3
CPU
V-Ray 5, update 2.3
GPU
V-Ray 5, update 2.3
CPU IPR
V-Ray 5, update 2.3
GPU IPR
Particle Shader
Points and Cellular Modes are not supported.
  • Phoenix Simulator → Volumetric Geometry/Volumetric Heat Haze/Isosurface rendering is not supported with V-Ray Next CPU IPR.
  • Phoenix Particle Shader rendering is not supported with V-Ray Next GPU and V-Ray Next GPU IPR.
Chaos Phoenix 5.22 Official
Release
V-Ray Next
CPU
V-Ray Next
GPU
V-Ray Next
CPU IPR
V-Ray Next
GPU IPR
Particle Shader
