« Previous Version 2 Next »
This page provides information on the V-Ray Fresnel Map.
VRayFresnel is a simple texture map that blends two colors or maps based on the angle of view and an index of refraction. For example, the user can connect the VRayFresnel texture to the specular color of a normal Maya material in order to create fresnel reflection.
To illustrate the texture's effect, the example on right shows VRayFresnel applied to the diffuse channel of a VRayMtl. The Front Color is set to Black, the Side Color is set to a bright cyan, and the IOR is set to 2.0
Properties
Fresnel IorSpecifies the index of refraction to use when calculating the Fresnel term.
Refract Ior –
Front ColorSpecifies the color for the texture when viewed frontally.
Side ColorSpecifies the color for the texture when viewed at a grazing angle.
