This page describes how to set up your local system so that it loads the files for the correct version.
Make sure to always have the latest Cinema 4D updates.
Installing V-Ray for Cinema 4D from a .zip file provides the advantage of easy setup and flexible folder management.
Required Steps
- Unpack the .zip file to a directory of your choice.
- Select the V-Ray folder and cut or copy it.
Paste it to the Maxon's plugins folder. By default, it is located in C:\Program Files\Maxon Cinema 4D Rxx\plugins.
If you already have an existing V-Ray folder there, replace it with the one from the archive.
- You are all set and ready to start Cinema 4D, where V-Ray is automatically loaded.
