« Previous Version 19 Next »
This page provides information on the Particle Tuner component.
The Particle Tuner uses custom logic to directly affect the particles of the Phoenix FD Simulator. It allows you to do very specific tweaks of the simulation which would otherwise be hard to achieve. It goes through all particles in the system from the Affect list changes the values only of those particles that pass the custom condition you created. Example Conditions and Actions would be:
  • If the Viscosity of a particle is higher than 0.5, then delete the particle.
  • If the distance from a particle to a mesh is less than 5, then reduce the Size of the Foam particle in the simulation.
  • If the RGB color of the particle is Red, only then affect the particle with a Maya Vortex Field.
You can construct simple conditions such as comparing a value from a particle channel to a number or measuring the distance from a particle to a mesh, and you can also combine many conditions in a complex expression using 'AND' and 'OR' logic. At each simulation step, the Particle Tuner will check each particle against this condition and it will modify the particle channel only if the condition passes. For example:
  • If a particle's RGB color is Red AND the Age is greater than 5, then increase the Viscosity for this particle.
This will essentially force the fluid to start solidifying if it is emitted from a Source whose RGB is set to Red, and 5 seconds have passed since the fluid was emitted. Fluid which is colored differently will not be affected by the Action, even if it's age is greater than 5.
Unlike the Phoenix FD Mapper, the Particle Tuner can also delete particles from the simulation.
The Particle Tuner is a powerful tool and it will not stop you from creating expressions such as "If the Age is higher than 0, delete the particle". This will kill all particles immediately after they are born which may cause confusion, so you must be careful.
Note that the Particle Tuner affects all Phoenix FD Simulators in the scene unless they explicitly exclude it.
Please note that in order to correctly copy/clone a Particle Tuner in Maya, you must use Edit -> Duplicate Special and check 'Duplicate input graph' and 'Assign unique name to children nodes'.
||Phoenix FD menu|| > Create > Particle Tuner
Enabled enabled – Animatable checkbox that turns on and off the effect of the Particle Tuner.
Affect | affectpartsys – Allows the Particle Tuner to separately affect the Liquid, Foam, Splash or Mist particles. You can also affect Drag particles in a Fire/Smoke simulation, but note that you cannot change their Velocity channel - they are simply dragged by the fluid. You could affect any Drag particle system by typing Drag in the list, or you can affect specific Drag particle systems by using their exact names.
When [ Edit Condition... ] –The Edit Condition window is used to construct a sequence of tests which are evaluated for every particle of the Phoenix FD Simulator, at each simulation Step. If the particle satisfies the condition, the selected Then actions are performed - Delete ParticleChange Particle Channel or Affect By Forces. Otherwise, the particle is ignored. By default, the condition is set to "Age > 1.000", therefore only those particles whose age is greater than one will be affected by the specified action. Time Scale different than 1 will affect the Particle Age used by the Particle Tuners. In order to get predictable results you will have to adjust the buildup time using this formula: Time Scale * Time in frames / Frames per second  See the Particle Channel Ranges page for more information on the channel ranges.
Then:
Delete Particle | tun_act_op_del – When the condition of the Tuner passes for a particle, it will be deleted. If this action is selected, Change Particle Channel and Affect By Forces will have no effect. Note that this is superior to the Clear Inside option from the Chaos Phoenix Per-Node Properties because it can also work for particles outside the simulation grid.
Change Particle Channel checkbox | tun_act_op_chan – When the condition of the Tuner passes for a particle, you can choose which of its particle channels will be changed and how:
Channel | act_chan – Selects the Particle Channel to affect. Note that if set to Viscosity or RGB, the channel value can be no lower than 0 and no higher than 1 - Viscosity and RGB are clamped strictly inside this range. The Channel can be one of: [ Size ], [ Age ], [ Viscosity ], [ RGB Red ], [ RGB Green ], [ RGB Blue ], [ Velocity X ], [ Velocity Y ], [ Velocity Z ], [ Speed ].
Action | act_chan_change – Specifies the type of action to perform on the selected Channel. You can choose to increase or decrease the value at each simulation step, or set it directly to a certain value.
Action Value | act_value – Specifies the value for the selected Action.
Buildup Time (sec) | buildup_time – Specifies the time it takes (in seconds) for the Channel to gradually reach the specified Action Value. If Buildup Time is 0, the effect is instant.
If the Buildup Time is set to 0, the specified Action will be executed for every step of the simulation. If the Steps per Frame parameter of the Simulator is set to a value higher than 1, the specified Action will be executed multiple times for a single frame.
Time Scale different than 1 will affect the Buildup Time of Particle Tuners. In order to get predictable results you will have to adjust the buildup time using this formula:
Affect By Forces | tun_act_op_force, partTunFSet – When the condition of the Tuner passes for a particle, you can choose which forces will affect it. You can pick Maya fields, Phoenix forces, Mappers, or even other Voxel or Particle Tuners. Using this, you can for example tell a force to only affect the fluid inside a volume, or only affect fluid with certain speed, or even based on a texture mask. When using native Maya fields in the Tuner, you can limit them only to certain particle systems using the Affect list - without using a Tuner, all particle systems in a simulator would be affected.
With Multiplier | tun_force_mult –  Multiplier for the strength of the forces. This is particularly useful for easily scaling the effect of Maya fields over a Phoenix simulation.
Edit Condition Window
The Edit Condition window is at the core of the Phoenix FD Particle Tuner. It consists of a Conditions Tree on the left and a Parameters panel for the individual elements in the tree on the right. The Delete ParticleChange Particle Channel or Affect By Forces actions will only be executed for the particles of the Simulator which satisfy the conditions tree.
The Conditions Tree is made up of the following expression types: Logic, Compare, Math, Value.
Folding (collapsing) of a tree item in the view to the left will show you a simplified view of the expression. For example, collapsing the tree in the image below will change its text to "Age > 1.000", meaning the Particle Tuner will affect only particles whose Age channel is higher than 1 second. You can also read a simplified view of the entire condition expression in the text box below the Edit Condition... button.
Value Expression Item
The Value Expression Item is the lowest level operator. It expects no sub-expressions but can be converted to a Math Expression by selecting it with the right mouse button in the Conditions Tree.
The Value Expression Item returns a raw number which can be either the value of a Particle Channel or a Texture for a given particle of the Phoenix FD Simulator, a manually-specified number in a certain range or the distance between a given particle and an object in the scene.
Numberval_typeval_number – returns the specified value.
Random Betweenval_type, val_rand_min, val_rand_max – returns a random number in the selected range. Note: a different value is generated for each particle of the Simulator. The value also changes for every frame.
Channelval_type, val_chan_part – returns the value of the specified Simulator Particle Channel for the current particle. You must have this particle channel enabled in the Output rollout of your Simulator. The Channel can be one of: [ Size ], [ Age ], [ Viscosity ], [ RGB Red ], [ RGB Green ], [ RGB Blue ], [ Velocity X ], [ Velocity Y ], [ Velocity Z ], [ Speed ]. You can find out more about the usual grid channel ranges in Phoenix here.
Distance Toval_typeval_dist_node – returns the distance from the current particle to the surface of the specified object. Will be positive if the particle is outside the object volume, and will be negative if the particle is inside the object volume. The distance is in simulation grid voxels. Note: currently you can only pick polygon meshes - measuring distance from the current particle to a nearest particle from a particle system is currently not supported.
Intensity Ofval_typeval_tex – returns the specified texture's color intensity in the position of the current particle. The Phoenix FD Simulator has no Explicit UV coordinates therefore you should add the texture as a projection (right click on a texture in the "Create Render Node" window → Create as Projection) for this to work.
Compare Expression Item
The Compare Expression Item evaluates to true if the specified condition is valid based on the provided sub-expressions. Otherwise, it evaluates to false.
To create a Compare Expression Item in the Conditions Tree, right-mouse-button click either on a Logic or a Compare expression and select "Replace with: New Comparison".
Compare Type | comp_type – Sets the comparison type to perform:
When set to "Is Greater Than", the Compare expression for a given particle will be true when the first Math/Value expression item should return a value larger than the second.
When set to "Is Less Than", the Compare expression for a given particle will be true when the first Math/Value expression item should return a value smaller than the second.
When set to "Is Equal To", the Compare expression for a given particle will be true when both Math/Value expression items evaluate to the same number.
Math Expression Item
The Math Expression Item returns a number calculated according to the specified Math Type and the provided sub-expressions.
To create a Math Expression Item in the Conditions Tree, right-mouse-button click either on a Math or a Value expression and select one of the "Replace with: (this) ..." options which contains a "+" , "-", "*" or "/" symbol.
Math Typemath_type – Sets the mathematical operation type to perform:
When set to "Plus", the Math expression returns the sum of the two Math/Value expressions below it.
When set to "Minus", the Math expression returns the difference of the two Math/Value expressions below it.
When set to "Multiplied by", the Math expression returns the product of the two Math/Value expressions below it.
When set to "Divided by", the Math expression returns the quotient of the two Math/Value expressions below it.
Logic Expression Item
The Logic Expression Item is a top level operator which returns a value of either True or False, depending on the specified Logic Type and the provided sub-expressions.
To create a Logic Expression Item in the Conditions Tree, right-mouse-button click either on a Logic or a Compare expression and select one of: "Replace with: (this) AND ... " or "Replace with: (this) OR ...".
Logic Type | logic_type – Sets the type of logic to use:
When set to "And", both Compare expressions below should evaluate to true for a given particle for the Logic Expression to be true.
When set to "Or", at least one of the two Compare expressions below should evaluate to true for a given particle for the Logic Expression to be true.
